Navigation & Audio HK and MP3 CDs
Originally Posted by JoeDentist
OK - lets get this straight for hopefully the last time - the Head Unit in the 05's will play true MP3 computer files off a burned cd-r or cd-rw. This means songs burned with a ripper like Music Match or Audiograbber. It has been documented and it is true. The "CD changer" is a separate unit made to hold 6 audio CD's, i.e. disks with CD type audio files - these are NOT MP3 disks, but seemingly the unit will read burned COPIES OF AUDIO CD'S.
It does not, however, display ID3 tag info. Basically the display shows something like "CD002-TR001" or something like that, where I think "CD002" is the folder and obviously "TR001" is the track number in that folder.
Current reports are that the Head Unit in the 2005's will NOT display any sort of MP3 track data tags. Sorry guys, maybe the next generation Mini will do that - or someone will come out with a Mini specific Head unit that plays MP3's, works with or without HK upgrade, and displays tags.
It has been reported that the HU will also play WAV, and some other digital audio files. When I get mine, I plan an extensive test that I will write up.
HK and MP3 CDs
I picked up my 2005 MCS two weeks ago. The HK unit does play mp3 CD's. I have burned them as mp3 player disks in Roxio and as a CD data disk also in Roxio. It plays both.
The worst part is finding 300 songs that I want to fit on a CD :-)
Please excuse my ignorance but I'm new to all this Mp3 stuff. After reading this thread, I just copied a few files out of my i-tunes library onto a CD R/W, so that when I PU my new MCS this friday or sat I want to see if it plays.
However, I noticed the file extensions for the songs were all .M4A. Will the head unit--or any other Mp3 PB unit--read these files?
If not, what do I need to do? I have the latest version of i-tunes as my importer. thanks, Jimbo
i think m4a files are "protected"
mpeg4 audio files. no mp3 cd player will read these, that i know of.
if you're importing using itunes, make sure you have mp3 selected in your import preferences.
if you're buying songs off of itunes, either find software that converts m4a to mp3, or burn them as an audio cd and rip them again to make standard mp3s.
the protection on songs from itunes is almost as annoying
as the stuff sony puts on their md player import software. i'll stop before i go into a rant about the riaa... anyway i've been liking emusic.com recently. less of a selection, but much cheaper, and you download mp3s, not m4a or other formats. sorry to ramble...
mpeg4 audio files. no mp3 cd player will read these, that i know of.if you're importing using itunes, make sure you have mp3 selected in your import preferences.
actually, i made a mistake, m4p is a protected mpeg4, m4a is... not? i think it's the same as an mp4. if you do a search for some software to convert mp4 to mp3, you might find what you're looking for. .. but if you've got an ipod, go for it! much easier
Ya know my curiousity got the best of me so I switched importing prefs to mp3 and did my "Top 25" playlist, selected convert to mp3, and it appears that they were converted. I then made sure the burning pref said Mp3 disk. I then tried to burn the converted files and i-tunes would not let me. I then changed the burn prefs to "data disk" and it looked like the burn process was starting when the cd ejected with a red box "Unknown error 4450" cannot burn disk message popped up
I guess my original error was not selecting mp3 before ripping 9.7 days of audio files into .m4a fles
man what a hassle and a half!
Again, I'm paying for an auxjack, and I have a pod...:smile:
man what a hassle and a half!Again, I'm paying for an auxjack, and I have a pod...:smile:
Originally Posted by Nando
Hi gang,
Does the HK stereo support CDs with MP3 files? You know, not an audio CD but a CD with a hundred or so MP3s.
If it does, any tips/tricks to burning the CDs. I burned one as an standard audio CD, and it skipped quite a bit. I will try burning at a slower speed.
Thanks,
Nando
Thanks,
Nando
Originally Posted by Revwillie
how does the MFSW work for navigating through folders? Does it only skip songs one by one or can you skip from folder to folder?
mp3 sorting method
How does the stereo sort MP3s? I haven't looked at it in detail yet, but I can't figure out the sorting method to the unit. It isn't alphabetical order.
My only guess is it reads them based on location on the CD and my burning software didn't burn them alphabetically.
I'm praying they release new firmware so it can display tags.
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
Navigation & Audio USB stick keeps repeating same folder
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
DanTheMan
48
Aug 24, 2004 06:28 AM
