Navigation & Audio AirPlay for your car
Old Jul 8, 2014 | 07:38 PM
qb84's Avatar
qb84
Hi everyone,
After testing a bunch of different bluetooth devices I never found one I was truly happy with. Last week I found this:
http://www.amazon.com/dp/B00L26YDA4/ref=pe_385040_30332200_TE_item
An AirPlay device that you can use instead of Bluetooth.It is mostly geared towards Apple devices but I know Android devices can stream to Airplay devices as well.
I received it today and it sounds great, no compression whatsoever. , it does lag like a second or two but that's because it is buffering.
If anyone is interested, Amazon has this code which takes $7 off 7NTWFHB7.
Just wanted to let you all know.
Old Jul 8, 2014 | 07:44 PM
cerenkov's Avatar
cerenkov
Will this let you stream music from music streaming services like pandora, iTunes radio, etc.? EDIT - Yes it will.
Anyone know how much data those services use on an hourly basis?
Old Jul 8, 2014 | 07:51 PM
qb84's Avatar
qb84
Yep, pretty much anything that plays audio has AirPlay support on iOS.
According to this page:
FREE EDITION
The free edition of Pandora can stream music over the Web at a bitrate of 128 Kpbs or 57.6MB per hour. This could mount up to a significant usage each month. For example, if you listed to Pandora for one hour each weekday while commuting, you would use at least 1.1GB over a month containing 20 workdays. This usage alone would put you over the limit on some data plans.
CELLULAR EDITION
Although 128 Kbps is the default rate of Wi-Fi, Pandora's iPhone app allows you to choose between 64 Kbps and 128 Kbps when using a cellular connection. The default setting is 64 Kbps. This halves the data use to 28.8MB per hour. In our 1 hour per day for 20 days per month example, data use would reduce to just over 500MB.
Old Jul 8, 2014 | 08:11 PM
cerenkov's Avatar
cerenkov
Thanks. I've been debating about activating the factory satellite radio (~$500 including the first year). I could do this, get better music selection, up my data plan from 1GB to 2GB and still come out way ahead.
I do use airplay via an airport express exclusively in the house for music. I just read about how you can modify an airport express to get power via a usb port/cigarette lighter, but this is cheaper and easier.
Old Jul 8, 2014 | 09:12 PM
TVPostSound's Avatar
TVPostSound
I contemplated activating my factory satellite, but getting an outboard SiriusXM receiver gets you more stations, thus more variety.
Old Jul 17, 2014 | 01:35 PM
devicemanager's Avatar
devicemanager
I called SiriusXM @ 866-635-2349 and received the 5 mo. select pkg for $20 back in February. I called a few days ago before the promo pricing expired and asked for the same deal which was honored with zero hassle from the rep. Some people get 5 mo. for $25, or 1 yr. for $77. Activation fee should be waived. If you get hassled tell them you'll stream Pandora if they won't cut you a deal. If you don't get a good deal hang up and call back.
Old Jul 17, 2014 | 04:49 PM
cerenkov's Avatar
cerenkov
Just for grins, I streamed iTunes Radio through Aux Jack (~20MB data in ~30 minutes), but holy crappy sound, does the Bluetooth or Airplay sound this bad?
elightbo
Aug 17, 2015 01:50 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Dashdog
Aug 10, 2015 06:17 AM
PatrikKN
Aug 5, 2015 09:10 PM
