Navigation & Audio Speaker Cutting In and Out
Old Mar 6, 2014 | 08:39 AM
redolphn's Avatar
redolphn
Hello,
I performed the X9331 swap last summer and never had an issue until recently. Now my right front speaker cuts in and out and usually the only way to get it playing sound again is if I turn up the volume real high.
When it stops working, if I put the fader and balancer over to just the right front speaker, I get absolutely nothing. It comes and goes on it's own - even if the car is not even moving.
Any ideas? If I take it into the dealer will they say my warranty is void due to the X9331 swap?
Thanks in advance!
Old Mar 6, 2014 | 08:58 AM
Kevin@Integral Audio's Avatar
The pin/socket connection may be loose at the X9331. Did you use the proper tool to remove it? Are you getting any static-y crackling at any time?
Check the X9331 connection first. If that isn't it, then you can always reverse the swap and take it in to your dealer. Technically, to deny coverage, the dealer would have to be able to prove that what you did with the X9331 caused whatever issue it is you are having. If you swapped the correct wires (and they aren't loose) then there is nothing you did that would be an issue.
If it isn't a loose connection at the X9331, it could be a range of other possibilities. Anything from a dying output BTL in the headunit, to an issue with the speaker.
Old Mar 6, 2014 | 09:03 AM
redolphn's Avatar
redolphn
Thank you for the quick reply.
I'll check the wire on the connector. I didn't have a molex removal tool, so I think I just used a small screwdriver at the time.
Old Mar 6, 2014 | 10:46 AM
Whew, that's tough...those things are tough enough to get out in one piece with the proper tool. If you used a screwdriver, that would be the primary suspect in my opinion. Good luck with it, let us know how you make out.
Old Apr 1, 2014 | 04:21 AM
Lucky7's Avatar
Lucky7
hello,
have you solve your problem ? It was a default to the wire connection at the X9331 connector ?
i have the same problem, the sound on the left in my mini is lower than right but if i turn up the volume, it is work fine.
I've got retrofit 3 way speaker focal 165 VR3 in front and focal elyptique in the rear...
Old Apr 8, 2014 | 08:56 AM
redolphn's Avatar
redolphn
Lucky7 -
No I haven't had a chance to troubleshoot the problem yet.
Did you fix yours? What was the cause?
Old Apr 8, 2014 | 10:50 AM
Lucky7's Avatar
Lucky7
No fix the problem, i check the wiring and the connections zoos as possible
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
ahorvath
Oct 3, 2015 01:13 AM
patsum
Oct 1, 2015 06:33 AM
