Navigation & Audio Auxiliary Jack issue
Old Apr 3, 2012 | 01:25 PM
shannagons's Avatar
shannagons
My 07 R56 makes a bit of a hissing sound when I plug my iPod into the auxiliary jack. I've used multiple devices and multiple adapters, but I always get the same hissin sound. The sound isn't completely awful and I can listen to music, but I was wondering if anyone else has run into this problem.
I was looking into the iPod adapter that connects into the stereo, but it's very labor intensive and fairly costly. Was wondering if anyone else has run ino this problem and what solutions have worked.
Old Apr 3, 2012 | 04:37 PM
Kirby11's Avatar
Kirby11
Have you played with the volume on the ipod too? On mine I have to go up on device volume and down on the stereo volume in order to reduce hissing.
Old Apr 3, 2012 | 05:29 PM
Rooooney's Avatar
Rooooney
I have the same problem. I have a feeling it's something behind the the actual input. If I jiggle mine just the right way it stops hissing completely. i'm taking mine apart Friday to inspect it and I'll report back if I fix it. I will tell you that the iPod input stinks in my opinion (perhaps mine is a bit outdated). The sound is weak compared to the aux and the display to change songs on the dash is complicated. Stick with the AUX in.
Old Apr 3, 2012 | 06:45 PM
sbeezy's Avatar
sbeezy
do you guys run the y-cable enabled i pod setup of do you guys have the ipod interface that connects to the CD changer pipe?
Old Apr 4, 2012 | 04:46 AM
schatzy62's Avatar
schatzy62
PLEASE head over to the NAV & AUDIO section that is where all the info on this is. There are many threads over there discussing this problem. Most likely it is a grounding issue which many have had.
Old Oct 11, 2012 | 12:51 AM
redmini86's Avatar
redmini86
Buy a ground loop isolator from amazon. it's about ten bucks. totally gets rid of all the hissing.
surfblue
Oct 24, 2018 01:20 AM
Inziladun
Sep 3, 2015 10:35 AM
Chippawaguy
Aug 19, 2015 10:59 AM
