Navigation & Audio Focal vs Image Dynamics?
One pad would be fine for a set of 61/2" speaker, now if you were using these in a sub box that would be a different story.
I only ever installed 1 pad and the difference was noticable. We had one customer come in for us to just intall the pads his system was already in place and the midbass noticably increased.
One trick I would show people in my car was to roll my window down so it would block the pad. Then the could hear it with a flat surface behind and then with the dynaxorb, it was a big difference . There are other factors on this too I was removing some of the speaker volume so I know its not a compleatly fair test but you get the idea.
they are super inexpensive for what results you get
Only a small area of the door behind the 6.5" speaker can be easily accessed. I have Dynamat Xtreme in there now. Are you saying that would be sufficient to absorb the back wave distortion? I'm doing this prophylactically, I don't have the new system installed yet, and I'm not sure I would be able to distinguish back wave distortion from speaker quality.
i think you are on overload with reading...turn your computer off for a few days an "process"....
That is great advice ,
You can drive yourself nuts over the details, I know I do sometimes (I am sure I am pouring kerosene on this fire for you
That is how I ended up with a set of $4700 speakers
It took me purchasing about 5 to 6 sets before I finally just bought the ones I wanted regardless of price
I think you mentioned you had a set installed before and you did not like them so it's good to have a reference point .
I do think its good to get into the door once so putting them in is cheap and takes about 2 minutes when you are already in the door.
I would ask yourself this , if you don't put them in do you think you would want to go back in later to do so? In other words are you the type that says to yourself
"I probably should have dont that while I was in the door ". If so them put em in reagardless of how hard/ how much area is back there . You can only work with what you have and sometimes that is a bar or sheet metal blocking something
Robin , what are you using to get a signal from the factory headunit?
I think what MiniSq is saying is there pleatly other areas that would take a front seat to this and he is correct. I feel like you get you $20 bucks worth on this accesory but it is not going to change your life.
).That is how I ended up with a set of $4700 speakers
Hippiehobbit267
Sep 1, 2015 06:13 PM
