Navigation & AudioAudio upgrades, bluetooth, and navigation discussions surrounding the Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
Do you have the hifi system? I have a 12" sub and amp I want to install and havent really looked to see who has done this yet...
Yes, Make sure you tap into the front woofers for the signal to the amp (if you are only going for a woofer install) The rear speakers have a terrible cut in signal and are almost unusable. If you want a true radio controlled switched power for the amp you will need to pull the headunit/speedo out to get the switched line otherwise you can tap into the cig lighter power in the rear and get power but only when the car is running.
He has been a little busy with the redesign of the original box. The first of the redesigned ones is in the mail coming my way as we type! WOOT! I am certain that he will get an update on here soon for you clubby guys.
