Navigation & Audio 2 speakers and a sub
Old Nov 16, 2008 | 10:38 AM
foxy1's Avatar
foxy1
hello there,
is it possible to connect 2, 6 x 9 speakers and a sub, to a 2 channel amp?
the amp i have is the lanzar vibe 800W if anyone was curios.
thanks to anyone that replies
Old Feb 4, 2009 | 08:20 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
yes......if the amp is bridgeable 2ohm stable and all three speakers are 8ohm each.
Old Feb 5, 2009 | 01:06 PM
riggz's Avatar
riggz
Which is most likely not the case heh. Doing this would be pretty pointless as the sub requires a lot more wattage. So you would either be underpowering the sub or overpowering the 6x9s. You would be better off with a seperate amp for the 6x9s.
Old Feb 21, 2009 | 11:45 PM
oheightmc's Avatar
oheightmc
you could, but the amp would have to be able to run mixed mono or play both stereo and mono simultaneously. you would also have a problem with the crossover. you need to have a low pass crossover keeping the bass (generally anything above 80Hz or so) out of the subwoofer. ideally you'd want to run a high pass crossover on the 6x9s. these passive crossovers use coils and caps identical to what you get when you have 2 way component set with a woofer and a tweeter. the active or electronic crossover which may be built into your amp can only highpass or lowpass, not both, since it's just a 2 channel and you have different speakers connect to it. they used to sell premade passive crossovers. you can build your own, but it's sort of a waste of time
honestly, i would just power the 6x9"s off the factory for now and use the lanzar amp to power just the sub. it will sound better that way because you will be able to adjust the output level of the sub to your liking on the amp.
Filmy
15
Jun 6, 2023 06:27 AM
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
