Navigation & Audio Post for mounting V1 using light switch plate?
Old May 8, 2007 | 11:42 AM
hunter99's Avatar
hunter99
A couple of months go in a thread there was a post where another member had customer mounted his V1 usig a blank light switch plate from Lowes. I have been searching for an hour and still canot locate the post. He had pictures and the way it mounted was very stealthy. Could someone direct me to this post if the know about it.
I plan on doing the same thing and want to see it again and possibly ask the member a couple of questions.
Old May 8, 2007 | 12:30 PM
jakay11's Avatar
jakay11
This is probably what you're thinking of
(Search results)
https://www.northamericanmotoring.co...archid=2734866
The mount your thinking of
https://www.northamericanmotoring.co...ntine+mounting
or
Good Luck
Old May 8, 2007 | 07:15 PM
hunter99's Avatar
hunter99
Thanks for the info. None of those had the write-up but I still have a good idea how it was done. BTW, the first link didn't work for me for some reason.
Thanks again!
Old May 9, 2007 | 08:11 AM
jwardell's Avatar
jwardell
I remember the post, and I remember replying to it...I've just spent 20 minutes trying all sorts of searches, and browsing through 20 pages of subscribed threads..and I still can't find it!
What makes it tough is NAM's search thinks V1 is too small a term so you can't search by that, and people don't usually spell out valentine each time.
Anyway, I planned to use his method till I came up with a little bit nicer way, using the included visor clip and a little velcro to attach it to the headliner.
http://www.jwardell.com/mini/v1.html
Old May 9, 2007 | 12:17 PM
gadgeTT's Avatar
gadgeTT
Not necessarily totally on-topic, but I've got an '06 MCS with Nav and here's what I did to mount my Valentine1 (V1) - using the suction cup mount, I have it stuck to the windshield just above the left side of my rear-view mirror. I then mounted the concealed display unit on the top of my steering wheel between the tach and speedo. It fits perfectly and doesn't block either. The display is perfectly in view between the tach and speedo, and the "mute" button is also easily accessible except when I'm turning.
Old May 9, 2007 | 01:50 PM
blalor's Avatar
blalor
I use Google to search NAM. vBulletin search sucks, has always sucked, and probably always *will* suck. Go to Google and prefix your search with "site:northamericanmotoring.com". That'll limit the scope to just NAM.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
