Navigation & Audio engine noise coming through speakers
Old May 4, 2007 | 07:41 AM
pimpedout97x's Avatar
pimpedout97x
just installed my 6.5" components in the front doors, and i have the amp (temporarliy) just laying in the boot, and you can hear a high pitched whine in the speakers when you hit the gas. cant hear it unless the volume is pretty low, but i still wanna fix it. is it becuase the amp is right over the battery (i read a few times that sometimes thats the issue)
Old May 4, 2007 | 12:12 PM
BBCooper's Avatar
BBCooper
"Sounds" like you have a groud loop problem.. It is very typical when adding components to the MINI audio system. Look for a groud loop isolator (GLI) device.. It can be found at Radio Shack for ~$16 with RCA end connections..
Plug this in close to the head unit (if possible) and the engine whine should be gone..
Good luck
Old May 4, 2007 | 01:22 PM
pimpedout97x
even though everything is aftermarket? (HU, amp, speakers, sub) im not using any of the stock wiring either.
where do i plug the RCA's from the GLI to though? got a link to one to give me a better idea?
Old May 4, 2007 | 01:24 PM
pimpedout97x
found one
http://www.radioshack.com/sm-see-all...i-2062214.html
Getrieben
Sep 12, 2024 07:03 AM
maestro39
Oct 27, 2015 02:38 PM
Mini'mon
Aug 26, 2015 01:02 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
