Need cheap and light 15" that fit Works Brakes
Old Apr 29, 2007 | 07:08 PM
Rawhyde's Avatar
Rawhyde
I want some cheap and lightweight 15" wheels that will work with JCW Brakes and some racing tires to use for autocrossing. There are some old posts that show 15 inchers over JCW Brakes. Are any still available? I'd prefer to have them in white, but it doesn't really matter that much.
Any ideas?
Rawhyde
Old Apr 29, 2007 | 07:33 PM
rkw's Avatar
rkw
There were several at TireRack that would fit, but the only one I recall at the moment is Kosei K1 TS. Check with Alex for other choices.
Old Apr 29, 2007 | 08:32 PM
Newdl's Avatar
Newdl
I was under the impression that there are no 15" wheels that fit JCW..........
Old Apr 29, 2007 | 08:51 PM
rkw's Avatar
rkw
No OEM 15" wheels fit, but there are 5 or 6 aftermarket 15" wheels that fit JCW.
Old May 2, 2007 | 04:27 PM
Alex@tirerack's Avatar
Alex@tirerack
JCW 15's - call me to order
OZ Ultraleggera
Motegi Tracklite
Kosei K1 TS
Those come to mind as light 15's that clear JCW's with NO spacer.
Alex
Old May 2, 2007 | 05:05 PM
Rawhyde's Avatar
Rawhyde
Thanks! The Kosei K1 TS link doesn't work. How about some autocross tires? Not for street use at all, just install them at the track....
Rawhyde
Originally Posted by Alex@tirerack
OZ Ultraleggera
Motegi Tracklite
Kosei K1 TS
Alex
Old May 2, 2007 | 08:01 PM
ygblat's Avatar
ygblat
Will the 15" SSR type C RS work?
Old May 2, 2007 | 08:25 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Rawhyde
Kosei K1 TS
http://www.tirerack.com/wheels/Wheel...re+7%2F12%2F06
15x7" +38mm offset $149 each 12.6 pounds Light Grey, Orange or silver painted finish
Gravity Cast/ Shot peened construction
For track or autocross use can fit-
205/50-15 small outer tire diameter good for autocross 22.8"
225/50-15
225/45-15 small outer tire diameter 22.8"
Dedicated autocross tires-
Check out
kumho V710 in 205/50-15 or 225/50-15
Hoosier A6 in 205/50-15 or 225/45-15
For slightly longer tread wear/durability
Avon Tech Ra in 205/50-15 or 225/45-15
Old May 2, 2007 | 08:29 PM
minihune's Avatar
minihune
At tirerack I don't see SSR type C RS in 15" size, only 17x7.5"
SSR Type C
15x6" only, $297 each (not too affordable/cheap), 8.8 pounds each
Old May 2, 2007 | 09:08 PM
ygblat's Avatar
ygblat
SSR Type C
Thanks, minihune, that's what I meant.
Old May 3, 2007 | 08:14 PM
shoeboy's Avatar
shoeboy
I think I remember reading something about Team Dynamics Pro Race 1 wheels having good brake clearance. I cannot back this up, however. Ignorance aside, they are 15x7" 14.1lb $133 12-spoke cast wheel. They also come in silver, anthracite and black.
Old May 3, 2007 | 10:16 PM
70spop's Avatar
70spop
If you want OEM 15" wheels, the 15" '07 R56 wheels will clear.
Old May 4, 2007 | 12:16 PM
Iautox's Avatar
Iautox
Will 07 MC 15" wheels fit a 07 MCS?
If the 07 MC 15" wheels fit JCW brakes will they fit on an 07 MCS? Alex at Tire Rack advised me to look up 15" wheels for my 07 MCS by plugging in a JCW R53 with a built date when the switch was made to the larger bolts. Therefore I would assume that 15" 07 MC wheels will fit an 07 MCS? But then again this could be a bit like the witch scene in Monty Python's Search for the Holy Grail. You know - a duck floats and wood floats so therefore if she weighs as much as a duck she must be a witch .....
Thanks,
Mark
Old May 4, 2007 | 12:49 PM
MINIAC's Avatar
MINIAC
The front discs are NOT the same on the R56 MCS and MC (294x22 versus 280x22), so R56 15" wheels won't fit over JCW brakes.
Old May 4, 2007 | 07:03 PM
johned206's Avatar
johned206
I hope this gets sorted out by next winter. My plan for my 2007 S was to get some cheap steel 15" wheels with snow tires mounted on them so I could swap back and forth. I'll be paying attention to see if any options emerge.
Old May 4, 2007 | 10:25 PM
70spop's Avatar
70spop
Oops, my mistake. I was under the impression that all of the R56s had the JCW brakes. Maybe it's just the "S" that has them. The rotors on the R56 Coopers look like the same parts, though.
Old May 10, 2007 | 12:50 PM
velocimini's Avatar
velocimini
I'm still confused- will the 15x7 Kosei K1 TS (or any other light aftermarket 15" wheel) fit over the 2007 MCS front brakes w/o spacers?
I want those 225 RA1s and Hoosiers for my track wheels if possible
Thanks for any help
Old May 10, 2007 | 06:03 PM
ygblat's Avatar
ygblat
Thanks for any help
I was tentatively told that the Motegis should fit, but this is still unsubstantiated info based on 06 JCW fitment. I would love to know for sure, as they would make for a killer track setup.
Old May 10, 2007 | 07:19 PM
minihune's Avatar
minihune
Thanks for any help
When I plug in 2007 MCS at tirerack.com I don't get any 15" wheel options so I don't think it will fit or at least tirerack's check on fitment doesn't suggest that it will fit.
When I plug in 2007 MCS with JCW kit I only get 17" wheels or larger.
For 2007 MCS tirerack has Motegi's in
Motegi Racing DV5 17x7 for $153 to 194 (chrome plated) each
Motegi Track Traklite in 16x6.5 ($306), 16x7 ($315), 17x7 ($280)
Motegi Track Touge 18x7.5 $225 to $270 (chrome plated) each
Old May 10, 2007 | 09:37 PM
rkw's Avatar
rkw
The TireRack website normally will not list wheels smaller than stock, even if they fit. Alex described a trick to getting it to list 15" wheels for MCS. You do it by shopping for winter wheels.
For vehicle select: Mini, 2006, Cooper S John Cooper Works, built after May 2006. Click on Shop for a Winter Tire & Wheel Package. Select 15" packages.
You should end up at this page:
http://www.tirerack.com/snow/WinterT...&performance=W
Now click on the link "Don't need tires? Skip to wheels".
The results list these 15x7 wheels (each has a variety of finishes/colors):
Kosei K1 TS
OZ Chrono HT
OZ Ultraleggera
Motegi Traklite
Motegi Traklite 2.0
Old May 12, 2007 | 08:41 AM
velocimini's Avatar
velocimini
Sorry to stay OT, but will these wheels then also fit a 2007 R56 MCS?
I had read the brakes are the same size as the JCW but was not sure.
I need to buy track wheels and the options for tires (Hoosier, Nitto, Toyo...) are so much better for the 15" size wheel (eg. 225/45/15).
Old Jul 17, 2007 | 09:20 PM
minihune's Avatar
minihune
Yes this short list of 15" rims at tirerack.com will fit any R56 MC or MCS and any 2006 MCS with JCW front brakes.
See
Kosei K1 TS
OZ Chrono HT
OZ Ultraleggera
Motegi Traklite
Motegi Traklite 2.0
Old Jul 19, 2007 | 07:58 AM
velocimini's Avatar
velocimini
Thanks!
It looks like Motegi Traklite 2.0s with 225/50/15 R-compounds should be a great track set-up.
Johannes
Old Jul 19, 2007 | 10:07 AM
jasonsmf's Avatar
jasonsmf
Just another point of reference- I have test fitted my 15's on a 2007 MCS R56- 15x7 Kosei K1 Racing does clear the front brakes (not by much...). I know those wheels do come up used from time to time with reasonable prices.
Jason
Wohnson89
Jun 10, 2020 04:53 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
