Suspension Is an alignment needed after springs?
Old Apr 29, 2007 | 05:29 PM
thebillsman's Avatar
thebillsman
Hey guys I'm just about to throw on a new set of H-Sport springs and people have been telling me that im going to need an alignment directly after, true?
thanks, tyler
Old Apr 29, 2007 | 05:35 PM
alfaholic's Avatar
alfaholic
Yes, but I would give the springs a couple of hundred miles to settle first.
Old Apr 29, 2007 | 05:41 PM
Methman's Avatar
Methman
Absolutely true!
Old Apr 29, 2007 | 05:47 PM
ChrisW's Avatar
ChrisW
True
Old Apr 29, 2007 | 05:58 PM
defylogik's Avatar
defylogik
i would wait at least a week before going to get an alignment. this will allow the springs to settle a bit, and drop the car a little more. take it with a grain of salt.
Old Apr 30, 2007 | 11:12 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Some owners report that after adding lowering springs their MINI works and feels fine. Yes there is more negative camber in the rear but if it is not more than -2.0 and if it is even on right to left and you don't mind the ride quality whatever it is then you don't have to do alignment right away.
However you can do alignment after any suspension upgrade that changes ride height. Partly do it to ensure that all is good and set with higher performance and safety in mind. Sometimes the right and left settings cannot be made equal after and upgrade. You can use front camber plates and rear lower control arms to give you maximum adjustability if these upgrades allow for that.
When I installed H-sport lowering springs my rear camber was about -2.2 degrees and ride quality was horrible. Very jarring, it rattled my entire front dash and all my tooth fillings. Once I had it aligned it was so much better.
Newer MINIs can allow for a little rear camber adjustment- 2005 or later using the lower rear control arm. 2007 MINIs can adjust a little front camber at the tower strut plate.
Even with a lowered MINI you can set alignment to factory specs if you have the adjustable suspension parts to allow for that. OEM specs will allow for best street handling, best comfort, and good tire wear.
melscoop
Mar 30, 2016 06:56 PM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
