205x45x17 vs 205x40x17
Old Apr 27, 2007 | 11:35 AM
marco621's Avatar
marco621
Okay so I'm at the point where I would like to purchase new wheels and tires.
Currently King Koopa's shoes are the s-heavies with pirelli's 205x45x17. I found a nice set of 5 spoke black wheels on ebay with Kumho Ecsta AST's 205x40x17 tires for a great price.
My only concern is how much the ride difference will be. I know there will definitely be a difference with the wheels only being 17lbs a piece but with a 205x40 tire, how does that compare to a 205x45.
King Koopa is strickly a street car but I would like it to perform as best as possible. Will the 205x40's be a huge difference than the 205x45's? I live in Northern New Jersey so roads are a problem here. In the future I do plan on adding FSD's but I would like new wheels and tires first. Should I just stick with 205x45 tires?
Any and all input is appreaciated as always. Thanks in advanced!
Old Apr 27, 2007 | 11:40 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
205/40's are fine. They will lower that ride height of the car a little because the sidewalls are lower. I had 205/40/17 toyo proxes4 and they were great. But I moved back to 45 for the sidewall. I wanted just a bit more to cushion me from potholes and bad roads. But if the price is right I would say go for it. If you don't like them you can always get a new set of rubber when those wear out.
Old Apr 27, 2007 | 11:44 AM
golden_child
on 205/40/17 before I h&r Springs.
Old Apr 27, 2007 | 01:58 PM
marco621's Avatar
marco621
mmm those look nice. are those the pro race 1.2's?
edit, nevermind, just saw it in your sig.
Old Apr 29, 2007 | 12:22 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Ride difference is not your only concern.
205/40-17 has a max load rating of 1102 pounds 23.5" outer tire diam $53
205/45-17 has a max load rating of 1235 pounds 24.3" outer tire diam $70
If you often carry four people in your MINI or need the odometer and speedometer to be accurate then the stock sized 205/45-17 tire size is better. Many of the older tires in 205/40-17 were even less on load rating and unusable for the MINI. Prices are significantly different.
40 series tires will be quite a bit more harsh riding than 45 series. Some additional noise and some added risk to your rims and suspension if you hit a pothole at speed. If you do long commutes the 205/45-17 is easier to live with.
Mrdi
Jun 15, 2014 07:16 AM
mrbubba
Jan 29, 2014 07:37 PM
Melody R53 euro mini
Oct 13, 2012 06:34 PM
Spinley
Jan 10, 2008 12:21 PM
planomini
Sep 12, 2007 10:59 AM
