Sloppy Centering Rings
Old Apr 24, 2007 | 07:44 PM
jasonsmf's Avatar
jasonsmf
Has anyone measured the fit of their centering rings onto the hub? I have the metal rings for my 15x7 Kosei K1 Racing wheels and there is a lot of clearance (slop). The hubs of my car measure about 2.205" and the I.D. of the centering rings measure 2.250".
.045" clearance is a lot if you ask me! The wheels shake a lot at speed, even after being balanced. If I carefully torque the lugs off the ground watching the centering ring to make sure it has equal air gap all the way around they run much smoother. When I made up a set of rings for my 949racing wheels, I used .010" clearance, the wheels are still easy to install and they run very very smooth. Unless I find out that I have incorrect rings for my Kosei's, I will most likely make up a new set of rings with a better fit.
Any input on this?
Jason
Old Apr 25, 2007 | 07:18 AM
cristo's Avatar
cristo
Alliance Member
Sounds like you have VW/Audi centering rings (57.1 mm = 2.248").
Mini size of 56.1 = 22.09" which is about what you correctly measured on the car.
Old Apr 25, 2007 | 07:29 AM
#20Works4me's Avatar
#20Works4me
I agree with Cristo, your hub rings are not for the Mini hub, the OD could be 73mm for the Kosei rims which is quite common for a lot of aftermarket rims, but you definitely need 56.1mm ID, your vibration problems will be gone.
Old Apr 25, 2007 | 07:53 AM
Bullfrog's Avatar
Bullfrog
Agree. Mine don't have any slop at all.
Old Apr 25, 2007 | 10:02 AM
jasonsmf's Avatar
jasonsmf
Thanks for the advice guys!
I have a new set of rings on the way, we'll see if they fit any better!
Jason
Old Apr 25, 2007 | 10:52 AM
minimusprime's Avatar
minimusprime
^^ agreed the ones that came with my oz's have no slop at all.
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
