R52 Sport Springs
Old Apr 24, 2007 | 05:21 PM
spinozaguy's Avatar
spinozaguy
Sport Springs
I like the lowered more aggressive look of the MINI Cabrio. I want to lower my mini with H-Sport Sport Springs or M7 Sport Springs. Can you just lower the vehicle without having to spend another $1000 in additional mods? My car is just a daily driver with maybe 2 or 3 runs a year. I can't see buying a lot of other suspension mods if I don't need them. Let me know what you think.
-guy
Old Apr 24, 2007 | 06:35 PM
JPit's Avatar
JPit
I have the M7 springs and it lowers the cabrio a little more than an inch. You will have to buy rear control arms as the slight adjustments that are build into the MINI will not get the camber back to where you want it.
Old Apr 24, 2007 | 07:20 PM
latte hiatus's Avatar
latte hiatus
^ Second that.
You should install one set of two rear lower control arms at the same time that you change your springs, as lowering will cause your rear wheels to develop quite a bit of negative camber. A good set of LCAs should run about $200 new, so you're not going to have to spend an additional $1K in complementary mods. However, if you're not already aware, modding is a slippery slope...
Old Apr 26, 2007 | 01:54 PM
HAVNPHUN's Avatar
HAVNPHUN
-guy
With a cabrio you might want to go with either coilovers or springs with a smaller drop like TSW so you don't ride around bumpstopping... check this out first before lowering your cabrio....
https://www.northamericanmotoring.co...light=DSCabrio
Old Apr 26, 2007 | 03:57 PM
dscabrio's Avatar
dscabrio
Return of an old thread.
I'm sure lowering a Cabrio depends on personal preferences and how harsh of a ride you can tolerate. I wouldn't recommend the H-Sports (or the H&R) and never tried the M7 springs. I may have missed posts about using the TSW spings on the Cabrio. After some experience, I think coilovers are probably the way to go but only if they have been tested with the Cabrio.
I am quite pleased with my stock springs and Koni FSD's, thank you. Although I am riding higher, I'm riding iin comfort.
Old May 2, 2007 | 12:58 PM
Intense's Avatar
Intense
252whp 200trq RMW style
I lowered my cabrio with the Eibach Pro Kit. I needed the rear lower control arms, bought those from Eibach as well.
1" drop in front and 1.2" in the rear. I love the way it looks and handles
Im running 215/35/18 Toyo Proxes4 tires so it rides pretty hard but I love it!
Whole thing installed was around $1,000
Old May 2, 2007 | 01:18 PM
bobdobbs's Avatar
bobdobbs
How much rear camber did you have without the control arms?
Old May 2, 2007 | 02:33 PM
Intense's Avatar
Intense
I don't remember the numbers but it was out pretty bad. ( might have the sheet in my car, I'll look when I get a chance) My passenger rear wheel was out more than the drivers side and it was really noticable. In fact, the car looked like it was sitting 2 inches lower in the rear due to the camber being so outa whack. The control arms were $250.00 for both of them and I would highly suggest getting them if you go ahead with the drop.
Some people have said that with the H&R springs they didn't need control arms..... I really question that
Old May 2, 2007 | 04:40 PM
latte hiatus
My rear camber was at about -4 on each side after lowering. It was quite dramatic - the MINI looked like it was knock-kneed. Needless to say, the car did NOT want to drive in a straight line.
Old May 2, 2007 | 10:28 PM
bobdobbs's Avatar
bobdobbs
Hmmm, interesting. I have the JCW suspension on my MCS and I have somewhere around -1.0 deg rear camber. The JCW drop is less than 1/2" so maybe that's why?
Old May 2, 2007 | 10:45 PM
latte hiatus
Right on the nose. More drop = more negative camber.
smdmini
Oct 7, 2019 06:05 AM
conky
Apr 6, 2016 08:03 PM
pewx3
29
Jan 15, 2016 11:14 AM
molala
Oct 2, 2015 01:53 PM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
