Suspension H-Sport Springs vs TSW Springs
Old Apr 16, 2007 | 02:47 PM
minimarks's Avatar
minimarks
Why should I get one over the other...Can't decide, want your input. Thanks
Old Apr 16, 2007 | 03:15 PM
hornguys's Avatar
hornguys
Pretty simple.
Do you want progressive (H-Sports) or linear (TSW)?
Do you need more than 30K out of the front springs?
Old Apr 16, 2007 | 04:38 PM
minimarks's Avatar
minimarks
Originally Posted by hornguys
Pretty simple.
That is what I can't decide...Which ones wouldn't get 30K?
Old Apr 16, 2007 | 04:49 PM
RedSkunk's Avatar
RedSkunk
The H-Sports also lower about 1" evenly, while TSW lower less, 3/4" or so, and a tad more in the back.
Hearing a direct comparison of both would be great, especially focusing on the spring rates (and not just trashing the progressive wind of the 'sports).
Old Apr 16, 2007 | 06:52 PM
minimarks's Avatar
minimarks
Exactly!
Old Apr 16, 2007 | 07:02 PM
txwerks's Avatar
txwerks
We've had people swap H-Sports out with our springs - hopefully someone will chime in and letcha know their opinion!
Old May 8, 2007 | 03:48 PM
sknandigam's Avatar
sknandigam
bump - I'm looking into purchasing springs at the moment.
Old May 8, 2007 | 05:44 PM
JIMINNI's Avatar
JIMINNI
snM3, I see you have the same size tires and rims i'm using,17x7 and 215/45/17, do you think we would have problems lowering our cars 1"?
Old Jan 17, 2010 | 07:46 PM
ofioliti's Avatar
ofioliti
Anyone?
Old Jan 17, 2010 | 09:56 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I sell both brands and would recommend the TSW's
http://www.waymotorworks.com/tsw-min...e-springs.html
Old Jan 18, 2010 | 06:47 AM
minimarks's Avatar
minimarks
Wow, talk about a thread back from the dead......
PS: Got the TSW's and still have them and still like them!
Old Jan 18, 2010 | 08:13 AM
ofioliti's Avatar
ofioliti
Great, Thanks, guys!
Old Jan 18, 2010 | 08:36 AM
Helix13mini's Avatar
Helix13mini
I've never seen the TSW springs, but I hear good things about them. We install the H-Sports with good results. BTW, the H-Sports don't fail after 30k, if that was the insinuation above.
Old Jan 18, 2010 | 09:09 AM
minimarks's Avatar
minimarks
Yea I have over 30,000 miles on the TSW's and I have friends with more than that on H-sports too. Both are quality products, which ones you use should be based solely on what you want to get out (performance characteristics) of the springs.
Old Jan 18, 2010 | 10:44 AM
ofioliti's Avatar
ofioliti
I notice that the TSWs lower the rear slightly more than the front. But even with that, is there still some positive rake left? (I guess I could go out and measure the rake on the MINI, but I'm lazy ...)
Old Jan 18, 2010 | 03:39 PM
minimarks's Avatar
minimarks
On my 06' yes there is. There were changes made on 05', 06's that took a bit of the rake out from the factory, so there should be even more on the 04'. Someone please correct me if that's not right, but believe it so. If your mainly looking for the most drop and best stance I'd have to say the H-sport wins but if ya want to track...TSW for the WIN!
Old Jan 18, 2010 | 05:14 PM
ofioliti's Avatar
ofioliti
OK, thanks. I did measure and there is about an inch and a half difference between the rear and the front (), so the TSWs will not even come close to leveling that out. (I do like the slight positive rake.)
Old Jan 18, 2010 | 05:32 PM
minimarks's Avatar
minimarks
Rake is goooood!
But when I first got the Mini, it looked like you could set a Ham in the rear wheel gap.... :(
Old Jan 20, 2010 | 05:27 PM
k_h_d's Avatar
k_h_d
When going with new springs, either TSW or H-sport what is the recommendation for struts? I have 68,000 miles on my stock springs and struts right now. I have read that the stock struts don't last much longer than that. Is that true?
Old Jan 20, 2010 | 05:47 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Stock dampeners are the weak link in the R53 suspension....For a better ride, even when not lowering your MINI, I would dump them soon as possible......no matter how many miles on them or what the circumstances.
They are a very poor match to the springs in our Sport Plus Suspensions. I base this on numerous MINI owners in my club who have maintained these OEM springs and just added koni yellows. All purport fantastic ride quality, handling.
I am sure you will be receiving tons of input on strut preferences. I have been using Bilstein for about 25+ years.....
Old Jan 20, 2010 | 06:14 PM
k_h_d's Avatar
k_h_d
Which Bilstein struts are you running?
Old Jan 20, 2010 | 06:29 PM
minimarks's Avatar
minimarks
I'm leaning towards the Koni Yellows that have been dyno matched.
Old Jan 20, 2010 | 07:33 PM
MrCooperS's Avatar
MrCooperS
Moderator
What's the difference between linear and progressive springs?
Old Jan 20, 2010 | 07:44 PM
ofioliti's Avatar
ofioliti
I think linear springs require the same increment of force to compress them, whereas progressives require increasing increments of force the more compressed the springs get. (Linears maintain their stifness with compression; progressives get stiffer with compression.)
Old Jan 20, 2010 | 08:28 PM
minimarks's Avatar
minimarks
A progressive spring basically has two spring rates, one softer at the first part of compression then going to a much firmer rate as the spring compresses more. Just for illustration, the first part might have a 100 pound rate and the second 300. Like two springs welded together.
A linear spring has a constant rate all the way across.
Why some like the linear better for track is because of the lack of transition from one rate to the other on the progressive spring. Which in say a sweeper, it can be harder to take and hold a set because of the possible back and forth of the rates. Where the linear is constant. BUT both can be used with success.
Where the progressive really shines is on the highway with the softer first rate as your traveling over small bumps in the road.
