R56 Wheels...17x8 goodness!
Old Apr 5, 2007 | 05:08 PM
ficcion's Avatar
ficcion
Just picked these up from Webb Motorsports.
Team Dynamics Pro Race 1.2, 17x8, 38mm offset, Hi-Power Silver
Just waiting on the 235/40/17 Bridgestone RE-01R's.
No spacers, no nothing. They fit as is!
Old Apr 5, 2007 | 05:13 PM
Passat774's Avatar
Passat774
Just wondering how you know that everything works if you have not even installed the tires yet??
Old Apr 5, 2007 | 05:32 PM
ficcion's Avatar
ficcion
I like to make things up...
Just kidding...Senor Webb has them on his R56 already (black ones). Some of you might have seen them in Vegas.
This is a great picture of the 17x8 (with 235 RA-1's) vs stock:
Old Apr 5, 2007 | 05:38 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I assume you tried to fit the bare rim on your new R56 MCS and it seemed to fit but the problem is that with the very wide 235mm tire mounted on the wide 8" rim you might have rubbing or you might not.
If the rim doesn't clear that's already cause for a spacer but so far so good.
So mount the tire and try again and if you get rubbing then post a few pictures and let us know what you can do to make it all fit.
If you are planning to lower your MINI you'll likely have some rubbing in the rear. Depends how low you go and your alignment settings.
Old Apr 6, 2007 | 05:06 PM
Passat774's Avatar
Passat774
Good, luck I look forward to seeing your "fitment" installed.
Old Apr 6, 2007 | 07:41 PM
ficcion's Avatar
ficcion
Please see third post in this thread. They are installed, and working well. The silver ones are just waiting to go on my car...the second install.
I was just happy to see that the R56 appears to have just a little more wiggle room than my R53's I have owned in the past. I could have never mounted these 17x8's with 235's on my R53 without spacers.
Old Apr 7, 2007 | 12:18 AM
MX100's Avatar
MX100
Great to hear!
I'm planning to run a 17 x 8 set up on my R56 as well! However, I'll prob go with 215 tire.
Are you planning to lower the car at all?
Old Apr 7, 2007 | 06:41 AM
ficcion's Avatar
ficcion
Originally Posted by MX100
Great to hear!
Randy Webb just lowered his R56 with the H & R springs. We'll see how it does at the first autocross coming up as far as rub is concerned...? So far it is driving well on the street.
I'll look to lower my "high clearance off roader" soon also.
Old Apr 7, 2007 | 07:20 AM
Passat774's Avatar
Passat774
Glad to know that 20's will fit even better on the new R56
Old Apr 7, 2007 | 04:36 PM
MX100's Avatar
MX100
Perfect! Hope to hear from you soon!
Keep us updated!
Old Apr 8, 2007 | 03:45 AM
03Indigo's Avatar
03Indigo
User Title's are Silly
great looking rim!!!
Old Apr 8, 2007 | 03:57 AM
07PepperS's Avatar
07PepperS
time to take her out dancin in her new shoes...
Old Apr 8, 2007 | 07:20 AM
HPUdrew's Avatar
HPUdrew
That is good to hear. I was discussing wheels in depth with a buddy who is going to get an R56. I told him that after checking out the R56 I think that 18x8 with 35-40mm offset will be a good fit, and due to the larger looking wheel wells/flares that 225/40-18s will look and function best. I guess we'll have to see if the additional tire width and height will work with a drop or not, but I'm glad to hear that others are already mounting 8" wide wheels, more width=more grip.
Drew
Old Apr 8, 2007 | 10:12 AM
Passat774's Avatar
Passat774
It does sound like that 225/40/18 will work too then on the R56!
Old Apr 18, 2007 | 10:32 AM
ficcion's Avatar
ficcion
235/40/17's with stock set up did fine on the autocross course. No dectectable rubbing or problem.
The lowered R56 (h&r springs) rubs just slightly on the outer edge of the tire against the fender liner both front and rear upon compression when racing/driving. Nothing significant enough to cause problem or issue. Just a little plastic on the underside of the fender is gently removed by the tire. As the car is lowered more negative camber is available. Roughly 1.5 degrees in the front.
All good news.
Old May 14, 2007 | 10:11 PM
Iautox's Avatar
Iautox
Since 235/40/17s fit will 225/50/15's
Arron at Outmotoring had told me that Pro Race 1's in 15x7 with a 45 offset will clear 2007 MCS brakes. 225/50/15's are a little narrower and shorter than 235/40/17's so I'm thinking they should fit fine - at least without a lowered suspension. Anyone have experience with this size or an informed opinion.
Thanks,
Mark
Old May 22, 2007 | 08:12 AM
benfica09's Avatar
benfica09
All good news.
great news.
looks like I know what my track setup will be.
Old May 24, 2007 | 11:57 AM
crazynates's Avatar
crazynates
I talked to Dan at H&R after I bought springs from him, I haven't lowered yet because I'm still looking for the right wheel/tires to lower on. he has black Rota R2's 17x7.5 with 235-35-17s (I'm 99% sure that's what he told me). the setup looks great and he said rides well also, with slight rub on hard track turns, not daily driving. i think I'll go with a similar setup. anyone got a line of some alternative wheels/tires in that category?
Old May 24, 2007 | 01:41 PM
HPUdrew's Avatar
HPUdrew
crazynates, there are TONS of 17x7.5" wide wheels out there for MINI's. That's what I have on mine (2nd set of this size) and lots of others have that size on their R53's.
Dan is probably running 235/40-17s, since that is a proper size tire. Sounds like either 7.5" or 8" wide wheels are the way to go on the R56. 215/45-17s work well on a 7.5" wide wheel, on an 8" wide I would run 235/40-17. Hope that helps.
Drew
Old May 24, 2007 | 01:43 PM
sandtoast500's Avatar
sandtoast500
Old May 24, 2007 | 03:46 PM
HPUdrew's Avatar
HPUdrew
Wow, nice list. I just bookmarked your post.
Drew
Old May 24, 2007 | 03:51 PM
sandtoast500
Yea, there should be a few in there that you like.:impatient
Old May 24, 2007 | 08:40 PM
Robin Casady's Avatar
Robin Casady
Noobie question: Why use 17 x 8 wheels for a 215 tire when they will fit on a 17 x 7 or 17 x 7.5?
Old May 24, 2007 | 09:59 PM
minihune's Avatar
minihune
Depending on wheel offset and suspension setup, MINIs can fit
17x7 Stock and a very common size good for imports
17x7.5 a bit wider but also a little heavier
17x8 still pretty common size for upgrades especially with deep dish designs.
17x8 is good for 225/45-17 or wider tires but MINIs have limited clearance so you have to find the right offset and right tire that fits snug enough.
If you are adding wheel fender flaring then it doesn't matter, get 17x9 or wider.
17x8 will look more aggressive on a MINI and stretch the 215/40 or 215/45 tire a bit wider than when mounted on a 17x7 rim. The extra weight of the 8" wide rim is offset by having more rubber to contact the road.
In the end it is a combination of tire choice, tire size and wheel size that gives the MINI the "right look" or "right feel". Some tires only come in 215mm wide sizes that will fit without rubbing.
Old May 25, 2007 | 06:41 PM
crazynates's Avatar
crazynates
Thanks for all that info, gents! I'll be sure to post whatever I decide on.
09R56
Nov 16, 2022 10:49 AM
Zettinger
Aug 25, 2015 04:04 PM
Accessory Products
Aug 11, 2015 12:19 PM
Shelly Cooper
Aug 10, 2015 12:05 PM
