R50/53 Dome light
Old Apr 5, 2007 | 04:14 AM
ga/girl's Avatar
ga/girl
Dome light
My dome light stays on after I open an close my door.I always have to push the dome button off .How can I just cut it off completely?
Old Apr 5, 2007 | 04:23 AM
NMgokart's Avatar
NMgokart
It is supposed to work that way; called "theater lighting". It will fade out after a preset time. Only way to do away with it completely is to pull the bulb.
Old Apr 5, 2007 | 09:41 AM
ga/girl's Avatar
ga/girl
It must stay on along time.Because I;ll be driving 30mins? And it's still own.
Old Apr 5, 2007 | 10:10 AM
rkw's Avatar
rkw
On my car ('06), my dome light comes on when I get in the car, and immediately goes off when I start the engine. If I don't start the engine, the dome light automatically goes off after about 15 seconds. I think your car has a problem and you should have your dealer look at it.
Old Apr 5, 2007 | 10:22 AM
Sissy's Avatar
Sissy
Mine has done this a couple of times, but it happens after I exit the car and lock the doors. I've waited up to 10 minutes before unlocking the car, turning off the dome light then shutting/locking the door. I have not gone to the dealer with it yet cause it doesn't happen often.
Old Apr 5, 2007 | 11:00 AM
buzzsaw's Avatar
buzzsaw
When you manually push the dome light button off--hold the button a few seconds and it will not illuminate again until you physically turn it back on. Discovered that on old posting.
Old Apr 5, 2007 | 11:38 AM
rkw's Avatar
rkw
I never knew that! I see it's described in the Owner's Manual. However ga/girl's car still needs to be checked by the dealer.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
