Suspension Is a 19mm rear sway on med = to 22mm on soft?
My buddy Jasun just put a 22mm rear sway bar on soft and loves it. I was wondering if I would get the same affects with a 19mm on med. Any info is appreciated.
Thank you
M
Thank you
M
Nope.....according to Alta, the 19mm at full stiff is still softer than the 22mm at full soft
http://www.altaminiperformance.com/p...-Bar-Rear-19MM
(click on charts for the numbers)
Not saying that the 19mm isn't a good improvement over stock....but it's still softer than the 22mm no matter how you slice it.
I assume the other manufacturers 19mm vs. 22mm are similar.
Jason
Jason
