Engine moving
Old Apr 2, 2007 | 03:39 AM
kamikazy's Avatar
kamikazy
Engine moving
My car Engine is moving a lot
do I need to change all Engine Stabilser
What parts do you recommend me to change?
Or it’s good enough to change the bushes?
Can you please list the part that I must change?
Regards,
Old Apr 2, 2007 | 04:14 AM
Minimad's Avatar
Minimad
#1 check the dogbone bushings on the right side of the motor (from driver position). Dogbone runs from block to firerwall mount by clutch line.
#2 check the motor mounts. One under the flywheel housing cover. One under the radiator mount.
#3 check other stabilser - you may have one from right front subframe to bottom lower right flywheel housing (under car)
Old Apr 2, 2007 | 11:10 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
The motor mounts on my old classics were rubber vulcanized to a metal plate, like the rear exhaust mount. They can come apart, alowing a lot of engine movement. I successfully replaced mine without removing the engine from the car.
Old Apr 2, 2007 | 11:19 AM
Mini Works's Avatar
Mini Works
Replace the dog bone bushings for sure, also make sure that the bottom bracket on the firellall is not cracked.
I also replace both lower mounts, even if you do not see any visual damage, replacing these two mounts, really makes a huge difference.
Victor
Old Apr 2, 2007 | 09:17 PM
kamikazy's Avatar
kamikazy
I found deferent types of brackets
1- MOTOR / ENGINE MOUNT MINI COOPER - OEM
2- ENGINE MOUNT W/NUTS MINI COOPER
3- MOTOR MOUNT SIDE ENGINE MINI COOPER
My car engines STABILIZER RODS are ok, need to change the bushes only
What type of bushes I must have?
1- POLY STEADY BUSH KIT 4 BUSHES PLUS SLEEVE MINI & COOPER
2- HARD POLY STABILISER BUSH KIT MINI & MINI COOPER S
3- FULL RACE UPRATED STABILIZER BUSH KIT MINI & MINI COOPER
Ore if you recommend other types please list it
Old Apr 3, 2007 | 04:42 AM
Minimad's Avatar
Minimad
Motor > #1 (never used 2, but may be easier?)
Bushings > #1 (#2 appears the same)
Old Apr 3, 2007 | 09:52 AM
shorn's Avatar
shorn
Motor Mounts - when I did my clutch relaease bearing job I found that someone (previous owner?) had cleverly tack welded the nuts to the motor mount which made their removal and reinstallation MUCH easier. Thank you, whoever you are.
Old Apr 3, 2007 | 12:16 PM
kamikazy's Avatar
kamikazy
Thank you.
W0TM8
Dec 19, 2019 07:50 AM
eatsleepautox
Oct 30, 2015 06:46 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
ShadyCoop
Aug 24, 2015 06:05 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
