Suspension FYI H&R spring rate info
Spring rate info directly from H&R USA 1-888-827-8881
RSS Club Sport - green springs
Front spring rate 545lbs/in Linear
Rear spring rate 405lbs/in Linear
Sport Coilover - red springs
Front spring rate 469lbs/in Progressive
Rear spring rate 240lbs/in Linear
The reply below explains how each kit works progressively.
Here's the skinny according to Joshua at H&R.
The Sport kit - red springs (not PCS) have true progressive rate front springs. The RSS kit have linear rate springs. However, the mini, is a "bumpstop Active Vehicle" due to its small suspension stroke. And so, both kits work progressively. The RSS kit ramps up faster and with a higher rate than the Sport kit.
smdmini
Oct 7, 2019 06:05 AM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
