R56 Fan running in MCS after a drive??
Old Mar 26, 2007 | 12:07 AM
fjork_duf's Avatar
fjork_duf
Just wondering if this is normal... After almost every drive the fan comes on for about 30 seconds when the car is parked. Is anyone else's MCS doing this? Is that normal? Or do I possibly have an over active temp sensor/fan?
Old Mar 26, 2007 | 12:19 AM
msh441's Avatar
msh441
Cooling the turbo, I bet.
If you really look close, you may also discover that that electical whirring noise isn't a fan at all (or at least not JUST a fan) but an electic water pump that's continuing to circulate coolant through the turbo unit. Basically a built-in turbo timer.
Don't worry.
Old Mar 26, 2007 | 12:45 AM
fjork_duf's Avatar
fjork_duf
Yes.. I've heard the hissing/cycling of water or oil or whatever, but the fan comes on frequently. If that's normal it's cool.
Old Mar 26, 2007 | 04:24 AM
vader's Avatar
vader
I too have noticed the noise for a short time.
Old Mar 26, 2007 | 05:43 AM
dneal's Avatar
dneal
Most modern cars have electric fans that run after the car is shut off.
Whether it's normal or not depends on what the weather is like in your area. If it's warm/hot... no issues. If you have still have snow on the ground, let the dealer know.
Old Mar 26, 2007 | 11:50 AM
fjork_duf's Avatar
fjork_duf
Thanks. I just haven't had a car run the fan like that after a drive before.
Old Mar 26, 2007 | 02:00 PM
KenL's Avatar
KenL
My MC (without turbo) also does it.
Old Mar 26, 2007 | 02:19 PM
Peef's Avatar
Peef
Mine does this as well. I believe what we are hearing is the water pump. It's my understanding that the water pump runs on demand as opposed to continuously as in most vehicles. This was done to save drag on the engine (and consequently lower fuel consumption). Presumably it'll save some wear and tear on the water pump, too.
Old Mar 30, 2007 | 05:02 PM
Rennie's Avatar
Rennie
Just wanted to add that my MC does it too. Tonight it ran for a few minutes.
Old Mar 30, 2007 | 06:23 PM
MotorMouth's Avatar
MotorMouth
Mines does on occasion.
Old Mar 30, 2007 | 07:28 PM
brohr01's Avatar
brohr01
Yes, The noise you are hearing on key off is the electric water pump. BMW / MINI has gone to this design in alot of the newer product line for a few reasons. The original reason for going to the electric pump was to help get the motor to operating temps quicker since a cold engine needs more fuel and with all of the gov't regulations BMW / MINI had to come up with ways to save 1% here, .5% here to lower fuel useage. With the new R56 and also the E90/91/92/93 335i sedans both being turbo'd cars the added cooling provided to the turbo when the car is shut down will greatly prolong the life of the turbo itself.
Old Mar 30, 2007 | 08:59 PM
ficcion's Avatar
ficcion
Over and above the coolant circulating for the turbo the actual radiator fan will also turn on after shutting off the car. This has been common on the 02, 05, and 07.
Old Mar 30, 2007 | 11:16 PM
MotorMouth's Avatar
MotorMouth
yup, The pump always runs but is fairly quiet. Sometimes the fan runs and it is much louder. There is no way to mistake the two.
Old Mar 31, 2007 | 06:04 PM
Rennie's Avatar
Rennie
If I'm understanding this correctly (I'm not a car person), this is normal for the turbo charged MCS. But what about the MC? I'm getting the fan running after I turn off the car on my MC, but not all the time. Normal for MC as well?
Cereall
Sep 5, 2019 06:05 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
David.R53
Sep 1, 2015 06:51 PM
clintmeister
Aug 12, 2015 11:11 AM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
