R52 Magnaflow on the 'Vert...still require custom fit?
Old Mar 21, 2007 | 02:25 PM
elonm's Avatar
elonm
Hello All!
I tried doing a search on this subject and found a few older posts about it, but nothing definitive.
Will the redesigned Magnaflow fit an '06 Cabrio without any additional custom fitting?
Thanks,
David
Old Mar 25, 2007 | 12:44 PM
Call's Avatar
Call
No.
Call
Old Mar 25, 2007 | 03:23 PM
meg's Avatar
meg
The redesign is for the hardtop only. I found a professional exhaust shop and they made it fit my 'vert and installed it for an additional $200.
Old Apr 17, 2007 | 12:08 AM
MiniWillie's Avatar
MiniWillie
Oops... I have a Magnaflow cat-back en route for my Cabrio S. I found the following on Outmotoring.com:
"Fits Cooper S convertible 2003-2006 with rebending of a section of the mid pipe as it wraps towards the rear mufflers. Any decent muffler shop should be able to do it."
Looks like the self-install won't happen. I've emailed Magnaflow for advice...
Old Apr 21, 2007 | 05:14 PM
MiniWillie's Avatar
MiniWillie
Magnaflow is installed! NO mod's necessary on '07 Cabrio S 'vert (which should be identical to the '06, right?) However... you have to remove the four reinforcing bars to get the old out and the new in. It was tough getting the bars back on; they're under a bit of compression. Just leave all bolts loose until all are started.
LOVE the sound. Woooo hooo!
Old Apr 21, 2007 | 10:40 PM
bostoncooper's Avatar
bostoncooper
What was the part number of the exhaust that you installed? Did it have two mufflers or a single muffler?
Old Apr 22, 2007 | 05:58 AM
MiniWillie's Avatar
MiniWillie
Magnaflow #16662, for 2004-06 MINI Cooper S. Twin mufflers, twin tips. Installs on existing hangers.
Old Dec 12, 2007 | 08:29 AM
mmatarella's Avatar
mmatarella
This is all so confusing... I see reports that the Magnaflow fits, others saying it needs to be tweaked. Are there building variances that some fit and others don't? Off to research what if any work with the M7 USS too.
I had a one ball done and botched by a local muffler shop. Took it to a local now defunct aftermarket place that catered to MINI's among others. Their fix made it worse and now it's butchered badly. So I need to just replace it and buy a complete cat back.
Aug 19, 2015 12:51 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
Aug 7, 2015 05:56 AM
