Will these RIMS fit MINI ONE?
Old Mar 16, 2007 | 04:43 AM
vodka's Avatar
vodka
Sorry, I'm RIMS dummy... can someone tell me which of these 17" RIMS will fit on MINI ONE and maybe can clear BBK too ?
BSA 214
BSA 220
BSA 311
Size : 15 x 7.0 16 x 7.5 17 x 7.5
Hole : 4/5 4/5 4/5
P.C.D : 98-120 98-120 98-120
Offset : 35/40/45 35/40/45 20/35/40
Ctr Hole : 67.1/73.1 67.1/73.1 67.1/73.1
BSA 349
Size : 15 x 6.5 16 x 7.0 17 x 7.0
Hole : 4 4 4
P.C.D : 98-114.3 98-114.3 98-114.3
Offset : 35-45 35-45 35-45
BSA 358
BSA 359
Thanks a million
Old Mar 19, 2007 | 12:22 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Look for 17x7 or 17x7.5
4x100 bolt pattern (Hole=4, PCD= 100)
Offset +40mm is better than +35mm
Centerhole 73.1mm (you'll need centering rings to fit your MINI hub 56.1mm) 67.1mm will also fit the MINI with a centering ring.
While these rims look nice I would estimate them to be heavy in 17x7 size for a MINI One. If you drive the speed limit you will be OK. Heavy rims will usually mean slower acceleration and longer stopping distances.
For centering rings ask the wheel vendor to send you a set of four that will fit both the rims and your MINI (56.1mm hub bore) or buy them for $22-31
http://www.1010tires.com/hubrings.asp
Be sure to order the right size.
Mini'mon
Aug 16, 2015 04:15 PM
nomar116
Aug 9, 2015 09:42 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
