How do you replace the polon filter???
Old Mar 11, 2007 | 04:14 PM
porschebreath's Avatar
porschebreath
Sorry , Im new and I'm sure this been asked befpore. The thing is huge and I can't figure out where it goes. Thanks in advance.
Old Mar 18, 2007 | 05:38 AM
msmith81's Avatar
msmith81
Sorry I don't have the magic answer for you, I don't have my own MINI, otherwise I'd snoop around and find it's location for you. If you're referring to the in-cab filter for the AC/heating system, they are usually located within the dash (or, more correctly, behind it). I have changed out some on Japanese imports that allowed you to remove a panel on the floorboard to get to the in-cab filter.
Old Mar 18, 2007 | 03:41 PM
spirit16's Avatar
spirit16
Cabin Air Filter location
The cabin air filter is located under the glove box against the firewall.
It is an on your back position to replace it.
You will need a fairly small slot screwdriver to pop the four tabs (two on the firewall side, two on the cabin side.
Careful when you do this as dust will fall when you remove the cover (faces the bottom).
Hope this helps
Old May 28, 2007 | 06:45 AM
mac020's Avatar
mac020
https://www.northamericanmotoring.co...t=cabin+filter
silence2-38554
98
Sep 21, 2016 02:52 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
