Interior/Exterior Weird question: "fuzzy" tape?
Old Mar 6, 2007 | 02:04 PM
ImagoX's Avatar
ImagoX
Does anyone know where one can get heavy-duty "fuzzy" cloth tape similar to what MINI uses around the various wiring looms under the dash? I've asked at a few hardware and electronics stores and received nothing but blank looks.
I have a set of wires that I'm having a real challenge hiding, and I figure that wrapping them in a totally matte, cloth tape would be better than nothing. I figure the "fuzzy" tape can be secured with the hook part of a small velcro dot as well...
Thanks!
Old Mar 6, 2007 | 02:22 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The tape can be gotten from MINI parts. It's the same stuff put between various panels and engagement points to stop squeaks and rattles.
IMO each car should come with a couple rolls standard.
Old Mar 6, 2007 | 02:24 PM
ImagoX's Avatar
ImagoX
Good idea - I have to pick up a part later this week anyway... Hope it's not TOO overpriced - it IS a MINI part after all.
Old Mar 6, 2007 | 08:43 PM
DixonL2's Avatar
DixonL2
Other means of hiding:
- "friction" cloth electrical tape (but if it's too exposed ot can get a little sticky)
- wiring loom (Radio Shack)
- Wrap with Scotch 33+ Electrical Tape, the best easily-available tape IMHO, but it's shinier black than you may want
- Hide in another wiring loom
- Use a longer run of wire and hide in side panels.
A lot depends on where you are running wire...
Old Mar 7, 2007 | 04:16 AM
JSWMCS's Avatar
JSWMCS
ace hardware sells black adhesive backed felt. that's what i use on my mini it's not the thin tape but you can cut strips out of it. it looks very similar.
-john
Old Mar 7, 2007 | 07:14 AM
DixonL2's Avatar
DixonL2
I forgot about that, also craft stores (Michaels, Joann fabric) sell the thinner adhesive backed felt. May not be the industrial strength adhesive you want though.
Old May 18, 2007 | 04:06 PM
kcchadmac's Avatar
kcchadmac
I too am in search of the "fuzzy" tape. I tried both a MINI dealer and a BMW dealer and they said they do not sell the tape. The MINI parts guy knew what I was talking about but said they only have it for internal use in the shop. Does anyone have a part number?
Old May 19, 2007 | 02:47 AM
umberto's Avatar
umberto
in my local Ace Hardware, they sell black 2" wide sticky velcro, industrial strength adhesive, by the foot....you could use just the felt half of that.....it would be too thick to wrap this around wires, but if there is a flat surface behind then you could just cover it up with this
Old May 19, 2007 | 05:44 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Check your local bicycle shop - we used to sell lots of black cloth tape with good adhesive on it about 20 years ago - though I think everyone uses much higher tech, cushier stuff now. But I found some online...
Old Oct 24, 2007 | 12:51 PM
robr3004's Avatar
robr3004
How did you make out with the Mini Dealership? Did they offer the fuzzy tape for sale or did you locate it somewhere else?
I'm currently searching for it to use with some of the LED projects.
Old Oct 24, 2007 | 01:11 PM
robr3004's Avatar
robr3004
I seem to have found it....just need to find a supplier
http://news.thomasnet.com/fullstory/29800
Old Oct 25, 2007 | 05:46 AM
Bhozar's Avatar
Bhozar
Try this: http://www.realoem.com/bmw/showparts...=61&fg=15&hl=5
I had a roll of this from BMW. Its not exactly fuzzy. This is a black material tape for going around the wiring looms. I have used a fair bit of it.
Old Oct 25, 2007 | 07:45 AM
Greatbear's Avatar
Greatbear
I have also used the 'carpet' side of Velcro tape in similar situations. It works well to prevent rattles, and it does well as a 'bumper' to prevent rattling in doors and compartments, and it works well as a foot or slider. While more expensive that simple fuzzy tape (I didnt pay anything for mine, a tech gave me a roll with a fair amount remaining), it's more durable and rugged.
Old Oct 25, 2007 | 09:39 AM
robr3004's Avatar
robr3004
Thanks Guys....I definately looking for the Fuzzy type since I need it to dampen vibrations from the wires I added in my doors for my LED Puddle Light Mod and Interor Handle LED Mod
I think I might go with the Velcro option since that is readily available.
Here is a pic of the mods in action:
Old Oct 25, 2007 | 01:39 PM
cooper517's Avatar
cooper517
wow that looks really cool!!
Old Oct 27, 2007 | 07:47 AM
robr3004's Avatar
robr3004
Thanks, I got all my inspiration from ImagoX
JHolland
Sep 24, 2020 08:20 AM
bctf1
Jan 2, 2016 04:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
whowantstorace
Sep 27, 2015 06:16 PM
