Anyone purchase Emilio's 949 wheels?
Just curious....has anyone purchased a set for their MINI? I've just installed a set on my monster Miata, and may, somewhere down the road, install a set on my 2006 MCS.
Jason
I have silver finish 15x8 rims and Hoosier A6 225/45-15 tires.
Rim weight about 13 pounds each.
My MCS has Bilstein PSS9 with about 1.7" drop with aggressive autocross alignment. -2.3 negative camber in front and -1.5 degrees in the rear.
Front fits just fine. Rear on left fits trailing arm with 1mm clearance no rubbing. Left rubs a little with certain wheel and not with another probably 1/2mm clearance only. No rubbing with my current adjustable Madness rear swaybar but depending on design of the rear bar there could be rubbing.
Planning for some wheel spacers for the rears about 2.5 to 3mm should work. Any more than that and I would have to change to longer wheel studs.
I've scrubbed in the tires and am waiting for march 25 for the next event. Seems OK.
I'm wondering if 36mm offset in the front and 40mm offset in the rear wouldn't be a better setup?
I bought an extra 40mm wheel just in case I destroy a wheel. Getting a replacement from Emilio may be difficult, as he's close to selling out in some colors/offsets. I've also thought about buying another 40mm wheel and two more 36mm wheels and mounting them on my MCS.
+40mm offset places the wheel further inside toward the center of the car. Since the trailing arm is part of the fixed suspension and cannot move then less offset is better about +33 to +34mm would do it for me.
In the front 949 has already checked and both +40 and +36mm offsets will fit OK no rubbing. I checked and +36mm is fine no problems.
I bought six wheels all +36mm offset for 2 extras. +40 is limited and fits only fronts. +36 wheels will fit front and rear and if needed with spacers in the rear if there is any rubbing.
Jason
BTW.....
I was out doing a little bit of test fitting tonight, I snapped a couple shots with the camera phone. Pay no attention to the road salt covered MINI, it's my daily driver :-D
At least the wheels look good
I finally was able to take some good pics of the 6ul's on the car. I made up a set of 1/4" spacers with centering rings to get the clearance I wanted on the rear trailing arm. I only need spacers on the rear, but I am running them both front and rear, just to keep track width equal. You can see from the picture of the spacer, I went ahead and drilled a second set of holes for 14mm studs....Just in case.
15x8 wheels work great for autocross
Just a note to let you know I used the 949.racing 6UL rims with 225/45-15 Hoosier A6 tires for autocross today.
We had only three runs for our championship in autocross.
Got off to a good start with rain looming overhead. On cold tires I got 1-1.5 seconds faster than the fastest competitor in SM class. I was able to do two more times even faster than my first run. I ran with about 36 psi in front and 33 in the rear and could have droped another 1-2 psi.
I use 3mm custom spacers only in the rear. Fronts work great no rubbing. With the spacers the rears work great.
Front track is not as wide as rear track and with spacers rear is much wider but still fine. I have been using Kumho V710s the last two years and the Hoosiers were just fine but I think I can do better with more practice.
I had a feeling that this comment was going to be made
My car is a northern Ohio daily driver, at stock height I am hitting chunks of snow/ice that have fallen off of other cars, so there is no lowering in my immediate future.
Jason
Jason
Good idea about doing a double drilling for older and newer bolts.
For your daily driving your set up is fine. You might even try not using front spacers. See if you can tell any difference, if youcan't then leave the spacers off.
Now go find a track or two to have some test runs and some fun.
The car maybe a daily driver, but these wheels are strictly track wheels w/r-compounds (I autox in SM, and do a handful of trackdays), which is precisely why I care about the small influence front/rear spacers have on handling. If I had my choice and was going to tune with spacers I'd go spacers up front and no spacers in the rear given the MINI's understeering nature. (looking at it strictly from a weight transfer point of view). Seeing as how I MUST run spacers at the rear to avoid interference, my theory was to keep the f/r track width differential the same as stock.
The autocross season doesn't start up here till mid April, track days shortly after that....so sitting around looking at the pretty new wheels is all I get for now
Jason
Jason
Some pics from my recent autocross in 6UL 15x8 +36 offset and Hoosier A6 tires in 225/45-15.
Worked pretty well. 3mm spacers on the rear only.
I need to figure out how to drive on the Hoosiers better, only my first outing.
ebowling
90
Aug 4, 2019 09:15 AM
SosoMINI
Nov 22, 2015 03:17 PM
ltjpunk7
Sep 6, 2015 07:32 AM
Mini'mon
Aug 16, 2015 04:15 PM
