have brakes been changed in 06?
Old Feb 27, 2007 | 08:45 PM
robino's Avatar
robino
i have someone asking me about my stock 06 brake set f/s and i'm not sure of the answer...
question is, will the brakes off my LATE 2006 fit any cooper S prior to Nov.06? If not, what changed?
I'm aware of the 14mm change in wheel bolts but not of a brake change...anyone??
Old Feb 27, 2007 | 09:03 PM
txwerks's Avatar
txwerks
Somewhere around 07/2006, MINI switched to a 294x22mm rotor from the prior 276x22mm rotor in the front... As such, you'd have the 294mm rotors if you have a post 07/06 build date.
I'm not sure if swapping rotors and calipers will work or not - maybe someone else would know? I don't believe that the hub changed, so it should work if you're selling calipers and rotors...
Old Feb 27, 2007 | 09:09 PM
robino's Avatar
robino
i should mention, i'm selling, calipers/rotors/pads/brake lines
so if the rotor changed (got bigger), is the caliper mount identical?
HaveATank
Aug 24, 2015 10:26 AM
sprp85
Aug 22, 2015 06:16 AM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
FLYM1N1
Aug 16, 2015 01:17 PM
