Interior/Exterior Modifying the rear wing/spoiler
Old Feb 27, 2007 | 11:22 AM
Roadsailer's Avatar
Roadsailer
Has anyone tried to modify the rear wing on a Cooper S to get some airflow over the rear window?
I'm thinking that if you could build up a boundary layer of air over the rear screen it might just stay a little cleaner
Thoughts anyone?
Paul
Old Feb 27, 2007 | 12:02 PM
TSR53's Avatar
TSR53
The uber wing is suppose to help keep the rear cleaner... according to a customer.
I've got one ready to install and will test for Northern Vermont conditions...
we'll see...
Old Feb 27, 2007 | 12:04 PM
Roadsailer's Avatar
Roadsailer
I'm surprised that it does any good re. the dirty water splashed up from the road. I thought it was only good for increasing the downforces.
Paul
Old Feb 27, 2007 | 12:25 PM
TSR53's Avatar
TSR53
That's what I thought also. Then read this thread >>
https://www.northamericanmotoring.co...ad.php?t=89422
one of the reasons I purchased. If it does help ANY to keep the dirt off, then great, otherwise I've got expensive kewl wingbling .
Old Feb 27, 2007 | 12:45 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I had witnessed the Dirty Boot Phenomenon while it happened right before my eyes. The conditions were perfect to actually see what happens.
I was on a stretch of Rt.9 and it rained not long before, the tar was wet, but my car was completely dry, but for some reason I had to keep hitting my rear wiper. After the wiper had cycled a few times, I could actually watch in my rear view mirror as the moisture/mist came up from under the car and wet the window.
Having witnessed this first hand, I believe the only way to keep the boot clean is to direct a constant flow of air over/down it, to counter the air coming up from underneath.
Old Feb 27, 2007 | 04:27 PM
VoiD's Avatar
VoiD
let us know if it is any good in keeping the rear clean..
Old Feb 27, 2007 | 09:19 PM
minimarks's Avatar
minimarks
Catching air and directing it down will create lift at the rear of car..
Old Feb 27, 2007 | 11:49 PM
xnotfunkylex's Avatar
xnotfunkylex
I heard from my local shop that a rear diffuser will help with that upflow of air/dirt that no one likes. Plus they look kind of cool. Maybe Maxmini from M7 will see this and tells us if his has any effect.
Old Feb 27, 2007 | 11:54 PM
COR BLMY's Avatar
COR BLMY
have you seen the WYVERN TAIL ???
Seems to help a bit ...
WITH the "flow through rear bumber" it does make some even greater difference...
sorry its raining ....
Old Feb 28, 2007 | 06:02 AM
TSR53's Avatar
TSR53
That's a kewl rear bumper anti-dirt mod, let us onto the details...
Originally Posted by COR BLMY
...WITH the "flow through rear bumper" it does make some even greater difference...
Old Feb 28, 2007 | 06:28 AM
62Lincoln's Avatar
62Lincoln
Where did you get that?
Old Feb 28, 2007 | 08:52 AM
COR BLMY's Avatar
COR BLMY
The "flow through" rear bumper was an early mod of mine.
Really very easy. The FAKE grills pop right out.
Bend and a bit of cutting of the heat shield.
You then have access to mount mesh without removing the bumper.
I can do the whole thing in about and hour now.
I will be doing one thiis weekend and will take photos and do a how-to
Old Feb 28, 2007 | 08:54 AM
COR BLMY's Avatar
COR BLMY
It is my prototype
Wyven Mini is my son and I.
PM me or look for us SOON
Old Feb 28, 2007 | 09:21 AM
sfjames2's Avatar
sfjames2
COR BLMY, nice work with the mesh there!!
I also did my own mod back there, but it was to the stock fake vents.
I'll have to post some pics., but basically the backing on the fake vents can be grinded away exposing the stock mesh pattern and allowing air to move right thru. Pretty easy to do and looks stock of course.
James
Old Feb 28, 2007 | 09:57 AM
ca$per's Avatar
ca$per
More down force less back draft wanted...
This tail looks very nice, but does it reduce the effect of upflow of air/dirt and keep the back a little cleaner?
another thing that I noticed is that it looks very similar to the M7 CF Front Splitter shown here in this pic (taken from maxmini & JCW Driver)
what do you guys think...
Old Feb 28, 2007 | 10:13 AM
COR BLMY's Avatar
COR BLMY
It does seem to help a bit with dirt / dust
(the MINI is still a box at speed )
YES ... the wing I built was to complement the M7 splitter.
I have the splitter and my wing...
now they both look like they belong.
NOTE:
The wing is NOT wind tunnel tested...
( well I have driven in a tunnel - with the wing .... )
I figure it doesn't hurt and I like the look
Old Feb 28, 2007 | 10:38 AM
ca$per's Avatar
ca$per
I don't think that I will be joining a F1 team anytime soon (that wind tunnel testing will not be needed at all)
I just hate that dirt on the rear end of my mini everytime I use it to go to work. I'm still looking for a good looking rear wing that gives a bit of more down force and some clean up service .. actually best bet is the JCW wing but the one used for racing and not the one that comes with the kit... I'd buy that if I can get my hands on one
good luck though and good stuff you got there
Old Feb 28, 2007 | 11:04 AM
Squirlz's Avatar
Squirlz
They do get a bit dirty back there don't they....
Old Feb 28, 2007 | 11:11 AM
COR BLMY's Avatar
COR BLMY
I did see one fellow who was just as much against dirt as you are, and many others
He had a small rubber strip mounted (glued) on the inside of the wing hole
(does that make sense ???)
I asked him about it and he said he had something simmilar on a EUV that had the same issue (I remember my dad had a foil on the back of the o'l station wagon, so us kids could be in the back with the window open)
He said it worked !
Old Feb 28, 2007 | 11:22 AM
TSR53's Avatar
TSR53
Here is an interesting find [pdf file from a Stanford Science Fair contestant], just googled "MINI Cooper wind tunnel" and..
http://www.vu.union.edu/~stroudj/index.htm
Old Feb 28, 2007 | 11:42 AM
ylwjkt's Avatar
ylwjkt
While the Cooper Motorsport racewing does improve the handling of the car, it unfortunately does nothing to improve the Dirty Boot Syndrome.
Old Feb 28, 2007 | 11:52 AM
Roadsailer's Avatar
Roadsailer
Those figures were "interesting" and seem to indicate that the spoiler on the back of our Minis increases the drag :impatient
Old Feb 28, 2007 | 12:07 PM
ca$per's Avatar
ca$per
but increases down force it is a give and take situation. In F1, it takes lots of data collection to find the perfect setup for each track... what do you need more, down force or top speed? you cannot have the best of the two, but you can set it up for your type of driving.
the way i'm driving now I need a wing to add 5-10 additional visual HP and was just looking also at the FBR CF rear spoiler, but it might be too much for me... anyone knows where I can get the JCW motorsport rear spoiler?
and a guy to always keep the MINIs' rear clean
Old Feb 28, 2007 | 12:18 PM
ylwjkt's Avatar
ylwjkt
I sent an email last summer to Paul Cooper (paulc@johncooper.co.uk)
and asked if he could ship me one. He replied almost immediately
and I had the wing at my front door three days later. You may try
that - or use the contact email address on the website.
Old Feb 28, 2007 | 12:36 PM
ca$per's Avatar
ca$per
very nice do you have a closer picture of it and how much did it cost?
thanks alot
