Electrical HEAD LIGHT problem
Old Feb 24, 2007 | 11:43 PM
harhoosh's Avatar
harhoosh
HEAD LIGHT problem
There is Sumthing wrong with 1 of my head lights.. when i switch it on.. one of them its not working.. i have to switch it off and on for many times till it switched On :s .. wuts the problem
Old Feb 25, 2007 | 03:35 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Loose connection maybe? Did you pop and slam your bonnet latly?
Old Feb 25, 2007 | 04:44 AM
harhoosh's Avatar
harhoosh
Noo..
I don't know why its happening like this.. :(
Old Feb 25, 2007 | 05:04 AM
Motor On's Avatar
Motor On
About how old are the bulbs? Are they OEM?
Loose conection sounds like a culprit is you pop your bonnet; the underside will have bludhe where the light is there is a metal spring clip, you can release that and bend back the plastic cover if they are the halogens (not xenons) then you should be able to see the plug, just check make sure its on tight.
Hope you can fix it easily and soon I know that kind of thing can be a pain and I'd hate for you to get a stopped or get a ticket cause the light decided to cut out.
phrza81
Oct 10, 2015 11:37 PM
cm.d
Aug 19, 2015 08:51 AM
jrezzo
Aug 9, 2015 10:32 PM
MIminiclubman
Aug 5, 2015 09:14 PM
