JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW head
Old Feb 22, 2007 | 07:31 AM
justintime's Avatar
justintime
JCW head
jcw head and remap. wasn't there a kit with that before? any idea where it went and if you can still get them? price range? power gains?
Old Feb 22, 2007 | 01:30 PM
txwerks's Avatar
txwerks
I wouldn't bother with the JCW head, personally... I've looked inside, and they barely do any work at all from what I can tell...
For the price, you'd be better served with a different aftermarket head and cam!
Old Feb 22, 2007 | 02:08 PM
Tüls's Avatar
Tüls
Turbius Maximus
the head is WAY over priced... and is only 15% over stock on the exhuast side only...
txwerks is right on par with what he said...
if you like I can get you the fireballed Mad Mod 1 head at anytime... for the special price of 1399.00 with all gaskets.... through the rogues...
Old Feb 22, 2007 | 02:10 PM
justintime's Avatar
justintime
haha thanks, I just have to decide if I want to save up for the turbo or head first decisions decisions. thats what I needed to know, I couldnt remember how much the head cost and if it was worth the money
Old Feb 22, 2007 | 06:55 PM
txwerks's Avatar
txwerks
A good head with a cam makes the Cooper so, SO fun to drive...
Old Feb 22, 2007 | 09:40 PM
justintime's Avatar
justintime
id like to see some dyno numbers :] sounds clips, and stuff. any one know of some links? I remember all the discussions about head work on the MC but I dont recall any actuall numbers.. you think with the head work, and an ITB setup it would push the same numbers as a TC mini running low boost?
Old Feb 22, 2007 | 10:16 PM
Dr Obnxs's Avatar
Dr Obnxs
First off...
I'll echo the voices of others. The JCW head isn't worth it's cost. That said, there's more to a re-worked head than just hitting it with a die grinder! Also, watch out for number, they are easy to be swamped by.
My best advice I can give is to work with your prefered vendor or tuner, discuss your need, and go from there. All aftermarket head work is NOT created equal!
And no, a head won't equal a turbo. But it will be a good base for the motor, give you a lot more at pretty much every RPM if you get the right kind of work done, and when you do add a turbo, it will give you more than if you hadn't done the head.....
Good luck,
Matt
Old Feb 22, 2007 | 10:30 PM
justintime's Avatar
justintime
Good luck,
Matt
thanks for you input matt, I meant a mc that has the head and an ITB set up, if that would match the power of a turbo mini running 6psi
Old Feb 23, 2007 | 06:44 AM
DragonSlayer's Avatar
DragonSlayer
Turbo on a MC Block. Danger; Danger; Will Robinson
Old Feb 23, 2007 | 10:41 AM
txwerks's Avatar
txwerks
It sounds just like any other Cooper with a CAI, Miltek header and Borla cat-back... Deep, throaty and awesome.
I don't believe in dyno numbers, personally - my guess would be north 140 whp and 135 ft/lbs. But, I can tell you that the car picked up SECONDS on the same track, with no other changes but the head and cam. Straight speeds were noticeably higher - by 5-10 mph depending on the straight. And, it's fully capable of breaking 140 mph...
Old Feb 23, 2007 | 10:46 AM
justintime's Avatar
justintime
thats what I like to hear :] the MC tranny has the gearing to get up there??
and sorry but what head are you talking about? or just in general
Old Feb 23, 2007 | 10:54 AM
txwerks's Avatar
txwerks
Yes, it does have the gearing (running MTH)...
We re-worked the head ourselves, by hand - if you search for the saga on NAM, you'll find it... It took about 80 hours to complete the head work and install it (9 hours to install). We spent about 70 hours really taking our time on the porting, shaping, and then went a bit overboard on the polishing part (which doesn't do a whole lot of good, but it was fun anyway), lapping the valves in by hand, re-assembling, checking, etc.
If I had to do it all over again, by hand, would I? Maybe... it was great fun and a beating at the same time. There are a lot of good head choices out there where someone else has put all the time/work into it that will get you 95%+ of what we ended up with... The extra time we spent probably netted such minimal gains that it wasn't really worth it in retrospect... but, we did it to do it, and were going to do everything we could to max it out...
phrza81
Oct 10, 2015 11:37 PM
caiken
Aug 27, 2015 06:55 AM
Aug 19, 2015 08:28 AM
MIminiclubman
Aug 5, 2015 09:14 PM
