Wilwood 13 in. brakes- what wheels?
Old Feb 20, 2007 | 01:20 PM
newbs49's Avatar
newbs49
I'd like to know who has the TCE Wilwood 13in kit and what wheels your running. Bought the kit for 06 GP and having problems with wheels to clear calipers. Any ideas? Do you need spacers also. Thanks
May have a brake Kit for sale. New
Old Feb 20, 2007 | 03:55 PM
CooperSS's Avatar
CooperSS
Yokohama Advan AVS T7 17x7.5
Old Feb 20, 2007 | 03:58 PM
newbs49's Avatar
newbs49
Very nice. May I ask where you got the wheels and what offset they are?
Any rubbing issues. Sure sits low.
Old Feb 20, 2007 | 04:06 PM
CooperSS's Avatar
CooperSS
M7 got them for me, I believe they are a 40 offset.
Those are 205/40/17 tires on the wheels, no rubbing from the tires but the bottom of the car is something else. Real LOW!!!
Bill
Old Feb 20, 2007 | 04:10 PM
MOTORN's Avatar
MOTORN
Originally Posted by CooperSS
Yokohama Advan AVS T717x7.5
What do they weigh?
Old Feb 20, 2007 | 05:36 PM
vader's Avatar
vader
I use 17x7 et45 Konig Holes, no spacers:
Old Feb 20, 2007 | 05:41 PM
newbs49's Avatar
newbs49
Do you know the weight. Man that caliper looks close to the rim. What size tire are you running.
Old Feb 20, 2007 | 05:47 PM
vader's Avatar
vader
Konig holes weigh 17lbs. Its not that close, there's at least 3mm clearance .
I've put lots of track miles (one or two DE's a month) never had an issue.
On the street, 215/40/17 all season, on the track 205/40/17 RA1s.
Old Feb 20, 2007 | 06:01 PM
newbs49's Avatar
newbs49
Track use is the concern. Motorn and me are looking for a rim for street and track. Do you think a larger RA1 will fit that rim without a problem?
Old Feb 20, 2007 | 07:00 PM
CooperSS's Avatar
CooperSS
Originally Posted by MOTORN
What do they weight?
I'm not sure, but I'll bet they are heavier than the Konigs and a lot lighter than "S Lites".
Bill
Old Feb 20, 2007 | 07:01 PM
CooperSS's Avatar
CooperSS
Correction from my earlier post, they are 41 offset.
Bill
Old Feb 20, 2007 | 07:09 PM
vader's Avatar
vader
The next size above the 205/40/17 in a RA1 is a 235/40/17 or 235/45/17 which really needs at least a 7.5" width preferably 8". Even if you get them on a wheel, you won't get them under the fenders without some surgery. 235 is too much for stock wheel wells.
Old Feb 20, 2007 | 08:19 PM
newbs49's Avatar
newbs49
Thanks Again. Does anyone have a 7.5 or 8.0 wide wheel setup out there?
Old Feb 21, 2007 | 06:00 AM
bean's Avatar
bean
i am running 17X7.5" SSR type C-RS wheels w/ 225/40/17 hoosier R6's. i previously have 205/40/17 RA-1's. a lot more room available w/ the toyos, but i love the hoosiers. i, too, have the 13" TCE/Willwood setup. i use 5mm spacers up front to clear my coilovers. the added space from the spacers works nicely w/ my bigger hoosiers. it is tight, but it works.
Old Feb 21, 2007 | 06:51 PM
newbs49's Avatar
newbs49
bean
Any rubbing issues. How much of a drop in your car?
Old Feb 22, 2007 | 11:41 AM
bean's Avatar
bean
i have about a 1 1/4" drop. i had a very slight rub on the outside in the back w/ my hoosiers. i'll raise the car about 1/8" and add a little more rear camber before my next track session.
Old Feb 22, 2007 | 02:55 PM
willum's Avatar
willum
This is what I have.....TCE Wilwood 13" with 17x7 Kazera KZ-V and Goodyear Eagle F-1's (215-45-17). The wheel combo is pretty tight but no spacers and no clearance issues with the caliper. 6+ track days as well. In retrospect, I would have gone with the smaller Wilwood BBK, only to have more tire/wheel options. Don't get me wrong, I love the set up I have now....just more options would be nice.
Old Feb 22, 2007 | 05:01 PM
newbs49's Avatar
newbs49
willum
Very nice setup. Is your car lowered at all.
Also how do you like the WMS bar on your car. I've been looking at it for my GP but wonder about the cost against the H-sport comp and Alta links that I had on my 03?
Old Feb 22, 2007 | 05:48 PM
MOTORN's Avatar
MOTORN
Team Dynamics Pro Race 1
These work and are for sale here:
not affiliated yada, yada, yada
https://www.northamericanmotoring.co...ad.php?t=92929
Old Feb 26, 2007 | 08:05 PM
willum's Avatar
willum
willum
The car isn't lowered....yet! Putting H-sports and Koni Yellow's at AMVIV in March. WMS bar is probably more bar than I need....but with the adjustable drop links you can "fine tune" the pre-load...if you're into that kind of adjustability. I have mine set at 3/4 stiff and seems to be just about right. Give Randy a call at WMS to get the full explanation of the differences.
FWIW...that tire/wheel combo weigh's 40.2lbs and the total weight of the car is 2681 with a 1/2 tank of fuel and nothing else in the car.
Old Apr 7, 2007 | 07:07 PM
newbs49's Avatar
newbs49
Any more options out there. I'm still looking for help.
Old Apr 7, 2007 | 08:48 PM
Wake|MCS's Avatar
Wake|MCS
You could always go custom, but that costs a pretty penny...
barnoun
Sep 17, 2018 05:04 PM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
