What to add to 2002 mini s?
Old Feb 16, 2007 | 11:31 PM
tl915's Avatar
tl915
I have a 2002 mini s with 15% pulley. It have now 75000km what kind of repair or update should I do to my car??
Old Feb 16, 2007 | 11:57 PM
cooper99's Avatar
cooper99
This is a pretty broad question to ask. Besides changing your oil, you might find some benefit in cleaning your Alta intake and replacing the spark plugs.
As far as other modifications go, to each their own, but I would say the majority of modded MCS owners get a stiffer rear sway bar and work from there. I wouldn't recommend lowering springs because you live in Canada and you probably need all the ground clearance you can get. You might look into getting some Koni FSD shocks that will improve your ride quality without sacraficing any clearance.
Old Feb 17, 2007 | 03:07 AM
tl915's Avatar
tl915
cooper99,
maybe I should narrow down my question. I do change oil every 5000km and clean my Alta intake every 10000km or so.
I have the following mod:
15% pulley
Alta CAI
Miltek header with Magnaflow Catback
Denso plugs
Mini-madness sway
H&R coilover
RDR front camber plate
What else should I do on my car?
Old Feb 17, 2007 | 04:00 AM
cooper99's Avatar
cooper99
Some other miscellaneous ideas that don't cost a fortune that make driving more convenient and enjoyable:
short shift kit
tint job
upgrade hi-beam driving lights
wheel stud conversion
low dust brake pads
paint brake calipers
Light-in-sight.com
ian's auto up
short antenna
radar scanner
Alta intercooler air diverter with sprayer
aero grill install
aftermarket gauges
rear seat delete
....the list is too long.
Old Feb 17, 2007 | 08:09 AM
herbie hind's Avatar
herbie hind
change all fluids hoses . go under and por all rust . do all you can to freshen it to like new condition.
Getrieben
Sep 12, 2024 07:03 AM
Mini'mon
Aug 16, 2015 04:15 PM
Colt45Magnus
Aug 13, 2015 11:18 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
Miniburb
Aug 7, 2015 03:45 PM
