C-Clamp or Caliper Tool?
Old Feb 13, 2007 | 04:04 PM
Red Scooter's Avatar
Red Scooter
OK. I replaced my front brake shoes myself. First time ever! Woot! Now I'm ready to do the rear ones.
I understand I need something that compresses AND turns the piston to make room for the new shoes.
But... ...which one do I really need? Obviously if I can use a $7 C-clamp instead of a $40 caliper tool, I'd like to. I even have a tool called a Disc Brake Pad Spreader that looks like this and was only $5.
What I don't know is, will it (or the C-clamp) rotate AND compress?
Advice please? Thanks!
Old Feb 13, 2007 | 04:07 PM
95Viper's Avatar
95Viper
The tool I hear you can get cheap from Harbour Freight is the ticket although I took my time and compressed with a c clamp and turned with needle nose plyers. It worked perfect. Would have been easier with the tool though.
Old Feb 13, 2007 | 04:15 PM
Red Scooter
I heard it was cheap but the kit in my OP is $40. You don't need the kit, just the compressor twisty thingy. But you can't buy just that.
That's why I bought the other thingy. From Randy Webb's post, I think I might be able to use a piece of rubber or wood to make the cheapo work. He used a C-clamp.
WHERE ARE THOSE CHEAP TOOLS???
Old Feb 13, 2007 | 04:54 PM
ScottinBend's Avatar
ScottinBend
You can get the Harbor Freight one for about $20 if you catch it on sale. You could even try having the store match the sale price. I have done that on other items that went off sale before I could get it.
Old Feb 13, 2007 | 05:12 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I've used a C-clamp for the rear calipers with no problem. You just have to tape the flat disc that flops around on the end of the threaded rod to the threaded rod so that they both turn together.
Old Feb 13, 2007 | 05:32 PM
Yo'sDad's Avatar
Yo'sDad
I've been on the Harbor Frt site looking for the little block to turn the piston in with... can't find it. Anyone found it and have a PN? Also, if you find something on the HF site you want, print out the page with price, if the price is higher in the store, they will honor the internet price.
YD
Old Feb 13, 2007 | 05:36 PM
Red Scooter
How about this?
You use it with a 3/8" ratchet and extension!
EDIT for Yo'sDad If it's this one, I found it here.
Old Feb 13, 2007 | 05:37 PM
Yo'sDad's Avatar
Yo'sDad
I just did a quick google and also found the same thing for less than $10.
http://www.etoolcart.com/index.asp?P...OD&ProdID=7710
thanks
YD
Old Feb 13, 2007 | 05:43 PM
Red Scooter
Looks like the Borg from Star Trek.
Just don't let 'them' implant it in your head!
Old Feb 13, 2007 | 05:50 PM
billie_morini's Avatar
billie_morini
I've used Partman's suggestion on other autos. It is stinky cheap
Old Feb 13, 2007 | 05:56 PM
txwerks's Avatar
txwerks
I use a pair of needlenose pliers and some Mechanix gloves, personally...
Old Feb 13, 2007 | 06:02 PM
Mini Works's Avatar
Mini Works
RedScooter,
The last tool you mentioned, the square one will not work without modifications,
as the fingers are set too far apart.
Victor
Old Feb 13, 2007 | 06:05 PM
Pebble's Avatar
Pebble
I got the Harbor Freight one for $20 direct from the store. Check out thier website for a local store. If you have never been to one before you should check out thier store anyway they are great. (if you are into that sort of thing!). I just got my replacement rear breaks today, this will be my first break job as the fronts were replaced under as part of a service. I just managed to wear them out in time!
Old Feb 13, 2007 | 06:24 PM
toddtce's Avatar
toddtce
Guess I'm lazy and use the TXWERKS method...although I do own one of those funky tools.
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Oct 1, 2015 08:55 AM
