offset for 235/40/17's without rubbing on 17x7.5's?
Old Feb 13, 2007 | 02:36 AM
fafnir's Avatar
fafnir
hi, what offset do i need to run 235/40/17's without rubbing?
e.g. what offset and what wheels?
and also, is there an offset that won't make you cut anything or dremel anything with the 235's?
thanks for the time
_
Old Feb 13, 2007 | 02:39 AM
fafnir's Avatar
fafnir
and also 245's (245/40/17's)?
_
Old Feb 18, 2007 | 11:29 AM
fafnir's Avatar
fafnir
bump
Old Feb 18, 2007 | 11:52 AM
newbs49's Avatar
newbs49
You should send an email to Alex at the Tire Rack for info. I don't think you can do 245's at all.
Old Feb 18, 2007 | 01:35 PM
Wake|MCS's Avatar
Wake|MCS
i don't think 245's would look good on a 7.5 wide wheel.. i'd do 225/40/17 if you can find that size... if not 215/40
Old Feb 18, 2007 | 06:14 PM
fafnir's Avatar
fafnir
if you look at tire choices on tirerack for 245's it opens up quite a bit more than even 235's which are a lot compared against 225's and so on
and also the tire size is consistent with the stock tire size where the 225's are a bit off
_
Old Feb 18, 2007 | 08:22 PM
Mini Fireman's Avatar
Mini Fireman
and also the tire size is consistent with the stock tire size where the 225's are a bit off_
I doubt you are going to be able to fit 245's or even 235's without some fender trimming (let alone if you are lowered at all). 225's even seem to rub for some peeps who run them. Of course the offset and whether or not you use spacers will affect fitment also. There are templates out there that can help you see what will fit.
Widths
215 = 8.5 in.
225 = 8.9 in.
235 = 9.3 in.
245 = 9.6 in.
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
Chibi2
May 19, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
