Suspension R56 shocks
Old Feb 7, 2007 | 06:10 AM
gwalsh's Avatar
gwalsh
R56 shocks
Anybody from across the pond know if the aftermarket shock applications from the R50/R53 will fit the R56?
Old Feb 7, 2007 | 10:34 AM
familiarstranger's Avatar
familiarstranger
I know that H&R has a set. I will search for a url
Old Feb 7, 2007 | 10:43 AM
dave's Avatar
dave
pug poo picker-upper
The R56 suspension is different than the R50/R53. The front struts on the R56 have about an inch more travel (I *think* the rears are about the same).
Old Feb 9, 2007 | 10:26 AM
Ryephile's Avatar
Ryephile
The front struts and rear shocks are very similar looking to the R50/53, however for sure the front struts use a smaller diameter spring, so right there they're not totally compatible. On top of that, the rumor of greater suspension travel implies different mounting points or damper configuration. The rear shocks look extremely similar to the R50/53; I can't spot a difference at a quick glance.
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Suspension Products
Sep 3, 2015 09:41 AM
