wider tires on stock rims
Old Feb 1, 2007 | 10:31 PM
rjtrout2000's Avatar
rjtrout2000
Is it bad to run a wider tire on a stock "holie" rim? I am looking at 185-65-15
Old Feb 1, 2007 | 10:54 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Seeing that im running or have been running a 205-50-15 for 3 years with no problems.. i would say nope your fine.
Old Feb 1, 2007 | 11:53 PM
rjtrout2000
awesome, thanks for the quick reply.
Old Feb 2, 2007 | 06:41 AM
rdelar01's Avatar
rdelar01
What tires are you thinking of? I need to be getting new tires in a few months.
I have the stock rims on my '05 MCC:
It has the same dimensions as the holies...5.5J x 15
Thanks!
Old Feb 2, 2007 | 06:53 AM
meb's Avatar
meb
There is an optimum tire size for every rim size. Just because others do it, doesn't mean it is correct. Look up your tire manufacturer and or wheel manufacturer. Either should have specs. Yuo will generally see three tire sizes suggested for each rim width with. Typically the middle tire size is highlighted by the manufacturer. Strtetching the sidewall out a bit will help perfornance. Installing a tire that is too wide for a given rim will result in lots of sidewall flex and reduce performance and tire wear.
Old Feb 2, 2007 | 06:50 PM
rjtrout2000
Thanks!
I was looking at the 185-65-15 because it would give a little more performance out of my all season tires (the continental tire that come in this size are more perofrmance oriented). The OEM rec. is 175-65-15, so its not much of a chnage but enough to notice a slight difference and still be driveable in all weather types.
Old Feb 2, 2007 | 11:06 PM
Mineon's Avatar
Mineon
I went smaller in diameter, but wider, on my 15x5.5 stock wheels. For summer use I'm using 195/55-15 Toyo T1R's and I couldn't be happier with the size or the tire. Even though they are wider, they weigh the same as stock, and the shorter diameter gives me slightly better effective gearing for quicker acceleration.
-Keith
Old Feb 3, 2007 | 12:44 AM
rjtrout2000
-Keith
That is one of the reasons I've been looking at running the 195-55-15 Flaken Ziex 512 for the summer, the whole quicker acceleration thing
Old Feb 6, 2007 | 10:32 AM
El_Jefe's Avatar
El_Jefe
thats a great tire, i have on 15x7" Konig rewinds 205/60/15's. that tire is great and holds up really well on the curves at higher speeds. Cheap assed tire, yet made in Japan! (vs mainland asia, ew)
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
FLYM1N1
Oct 13, 2015 04:33 PM
gmonde
Sep 8, 2015 06:37 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
nomar116
Aug 9, 2015 09:42 AM
