I Need Help With This One - Check Filler Cap
Old Jan 29, 2007 | 11:41 AM
ronstoys1's Avatar
ronstoys1
I would appreciate any input on this one...I have an '03 Mini Cooper ( Not an "S"). A light comes on the dash "Check Filler Cap", I have replaced the filler cap and the light still comes on after running for a while. Can anyone help me. Thanks, Ron
Old Jan 29, 2007 | 12:30 PM
Squirlz's Avatar
Squirlz
Maybe it wants you to tighten the filler cap?
Old Jan 29, 2007 | 12:44 PM
MOE4me's Avatar
MOE4me
Not really sure which "filler cap" your light is referring to. If it's the fuel filler cap, heres a wag:
I once had a habit of "topping off" my fuel tank - i.e. continuing to add fuel once the filler nozzle auto stopped (not in my MINI - I've learned since then). The backed up fuel eventually killed a sensor that was in the fuel rebreather circuit which caused a fault in my obc. Didn't know about it until I tried to pass my next DOT emmissions test.
Don't know if that will help, but it's something...
Old Jan 30, 2007 | 02:38 PM
SRICHS's Avatar
SRICHS
Check the Purge valve in the front of the motor, on the right hand side, when the vehicle is running. [ after about 3 minutes of running] Do you hear it clicking? if not replace it, if so remove the lines from both sides and check to see if any crud falls out. this is the valve that causes the check gas cap to turn on.
Old Jan 30, 2007 | 04:59 PM
ronstoys1's Avatar
ronstoys1
Thanks Srichs 1st gear I will try your suggestion. ron
Old Feb 3, 2007 | 08:32 AM
ronstoys1's Avatar
ronstoys1
Check Filler Cap
Srichs..You had mentioned a smoke test to check for leaks, how do you do it and where do you get the stuff? I got your note on checking the hoses @ the filler cap and will try that. I checked with BMW parts and with a discount the carbon cannister is around $90.00 and would take 3 weeks to get. I will be looking forwards to hearing form you. Thanks for helping me out and trying to save me some money. Ron
blackie
Jan 18, 2017 09:56 PM
Knuckle14
Aug 26, 2015 08:10 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
