Electrical After-market Driving Lamp wiring question
Old Dec 23, 2006 | 04:44 AM
Sheenabea's Avatar
Sheenabea
I have recently purchased and received some after-market driving lamps (rally lights), Hella Optilux's "Angel Eye". It comes with everything you need to install, but nothing in great detail about what fuse to use.
What fuse do those of you who have driving lamps/rally lights have them on? I know the OEM ones are wired on the same switch as high beams, but is it also on the same fuse?
If I don't wire it to the high beams, could I still use that fuse?
Thanks in advance!!
Old Dec 23, 2006 | 06:22 AM
ProfessorDave's Avatar
ProfessorDave
I don't see why you couldn't use that fuse, but it is much simpler to tap into the hot wire of the high beam. Some prefer to do this right at the headlight (which is the method used in the sticky in this forum...it is really excellent by the way and helped me alot in my install), other are bold enough to find that wire inside the cabin (it's hiding in a wiring harness with about a hundred other wires!).
Old Dec 23, 2006 | 06:24 AM
ProfessorDave
Oops...my bad: the sticky is over in interior/exterior mods https://www.northamericanmotoring.co...ad.php?t=29482
Old Dec 23, 2006 | 06:40 AM
jonnieoh's Avatar
jonnieoh
Yes, with mine, I tapped into the high beam wire right behind the driver's side headlamp, which, in my '04 MCS with xenons, is a green/yellow wire. The kit I had from IPF had a plastic snap-on bridge connecter, which you click onto the high beam wire. By doing so, the insulation is stripped enough to have a piece of metal make a bridge over to the kits' wire. Slap on some electrical tape, and you're good to go. My kit had its' own fuse, inline on the kit's wire...
This is the kit that comes with the Alta rally style light bar.
Old Dec 23, 2006 | 06:57 AM
kenchan's Avatar
kenchan
basically any switched fuse would work for your trigger wire.
Old Dec 23, 2006 | 08:01 AM
chows4us's Avatar
chows4us
Originally Posted by ProfessorDave
I don't see why you couldn't use that fuse, .
No sorry Dave, do not use the same fuse.
See here http://www.rallylights.com/useful_in...amp_wiring.htm
use an inline 30 amp fuse with 12g wires for two lamps to be safe.
Old Dec 23, 2006 | 11:22 AM
kenchan's Avatar
kenchan
^^ +1
yah, for your power supply, make a direct connection.
ryGuyMCS
Oct 20, 2015 02:24 PM
blackie
Aug 23, 2015 08:44 PM
Powershift
Aug 16, 2015 05:14 PM
DWooderson
Aug 10, 2015 09:12 AM
