R50/53 Outside temp gauge
Old Dec 19, 2006 | 07:54 AM
oliverm's Avatar
oliverm
Outside temp gauge
This morning my outside temp. gauge was reading 37° when I started up. I got about 500 feet when the outside temp. gauge started flashing and had a alarm sound with it. This lasted about 3 sec. Does anybody know what that was about?
Old Dec 19, 2006 | 07:56 AM
ChrisW's Avatar
ChrisW
Yep, Its because water starts turning to ice at 37 so its warning you that the roads could be icey
Old Dec 19, 2006 | 08:33 AM
Gromit801's Avatar
Gromit801
The possibility of ice on the roads, to let you know your tires are very cold and don't have as much grip.
Old Dec 19, 2006 | 08:35 AM
Eric_Rowland's Avatar
Eric_Rowland
That, or it's your biological clock. It dings when you turn 37.
Old Dec 19, 2006 | 08:42 AM
MiniMaybee's Avatar
MiniMaybee
My wife and I always laugh when it chimes because its like Matilda is saying "Hey, it's cold and there could be ice - don't hurt me".
Oh and water doesn't turn to ice until 32 deg F but I guess MINI is assuming that the ground temp may be cooler than the air temp, or simply throw'n it out there should you care that it is actually 37 deg F or less.
Old Dec 19, 2006 | 05:30 PM
capnmini's Avatar
capnmini
Its there to warn you that there's a hot 37 year old mom in the vacinity
Old Dec 19, 2006 | 05:36 PM
ChrisW's Avatar
ChrisW
I hate to say this but water starts turning to ice at 37 F it doesn't totally freez untill 32 F.
Old Dec 20, 2006 | 08:51 AM
Hyper!!!Blue!!!'s Avatar
Hyper!!!Blue!!!
Sorry man, but you need to go back to high school science class if you believe that water turns to ice at 37 F.
Old Dec 20, 2006 | 08:58 AM
MiniMaybee's Avatar
MiniMaybee
You're right! But I was assuming standard atmospheric pressure.
Old Dec 20, 2006 | 09:19 AM
ChrisW's Avatar
ChrisW
STARTS TO TURN TO ICE. READ WHAT I AM SAYING. I think you need to take a college chemistry class.
Yes you are right, assuming all the variable don't come into play you are right.
Old Dec 20, 2006 | 10:20 AM
tdm156's Avatar
tdm156
Ruling the curves
Its a warning that you have not finished your Christmas shopping and you better get going quick!
Old Dec 20, 2006 | 10:25 AM
mmatarella's Avatar
mmatarella
Now there's a option I'd pay for! Is that OEM or aftermarket?
Old Dec 20, 2006 | 10:38 AM
capnmini's Avatar
capnmini
Im pretty sure thats an aftermarket accesory easlily found in any town near you
Old Dec 20, 2006 | 10:44 AM
Eric_Rowland
Though I am loathe to cite wikipedia, this paragraph explains it pretty well:
Black ice may form even when the ambient temperature is several degrees above the NTP freezing point of water. This occurs typically (and treacherously) when terrain contours and/or prevailing winds cause a local steep differential of atmospheric pressure and/or temperature, or when the atmosphere has warmed up after a prolonged cold spell that leaves the temperature of the ground and roadway well below the freezing point.
Old Dec 20, 2006 | 10:57 AM
kramseib's Avatar
kramseib
Talking about temperatures. Did you know that -40 F is equal to -40 C.
Old Dec 20, 2006 | 11:12 AM
ChrisW's Avatar
ChrisW
Uh i think your wrong because the converson is °F = 1.8(°C) + 32 so i don't see how that could be correct.
Old Dec 20, 2006 | 11:19 AM
DrkSlvrS's Avatar
DrkSlvrS
Check out www.manuelsweb.com/temp.htm for conversion
Old Dec 20, 2006 | 11:23 AM
ChrisW's Avatar
ChrisW
Hmm well what do you know.
Old Dec 20, 2006 | 12:13 PM
Eric_Rowland
You had the formula, do the math!
One of those interesting fun facts.
Old Dec 20, 2006 | 09:50 PM
ChrisW's Avatar
ChrisW
Yea well its not like i get to convert -40 everyday. I wonder if the atoms are at the same excited state. I might have to look into this.
hey Hyper!!!Blue I'll give you one other lession today depending on the pressure you can go from a gas state to a soild state or from a solid state to a gas state. You never have to have a liquid state. But i guess you wouldn't learn that in High school science.
Old Dec 20, 2006 | 10:27 PM
Eric_Rowland
Yea well its not like i get to convert -40 everyday. ...
California sissy.
Old Dec 21, 2006 | 09:58 AM
MiniMaybee's Avatar
MiniMaybee
Called sublimation - happens here all the time in the winter.
Old Dec 21, 2006 | 01:33 PM
ChrisW's Avatar
ChrisW
YAY someone with a brain. I would have used sublimation but i wasn't sure how many people who know what it means.
Old Dec 21, 2006 | 02:18 PM
MiniMaybee's Avatar
MiniMaybee
I think you might be surprised with how many very intelligent people are here on NAM. Scientists, engineers and physicists. Really quite a bright group for the most part.
But then again we all bought a MINI - must have at least half a brain.
Old Dec 21, 2006 | 02:23 PM
agranger's Avatar
agranger
sublimation doesn't need extrordinary high or low pressures... See your everyday mothball for a good example of sublimation (solid to gas) at STP.
