Headlight Washer Problem...
Old Dec 18, 2006 | 05:22 PM
Rawhyde's Avatar
Rawhyde
RESOLVED: Headlight Washer Problem...
On the way home from work, I had the need to wash my windshield. When I did, I noticed that the headlight washers acted funny....too much fluid on one side, and none on the other side.
I stopped at a store and activated the washers again and ran around to the front....
Both washers popped out.
The Passenger side GUSHED out a blob of fluid twice
the driver's side didn't spray anything
I opened the bonnet and manually extended the headlight washers. On the passenger side washer, there was an oblong soft rubber plug just before the nozzles that had a bare metal spring sticking straight up. I couldn't see a similar feature on the driver's side washer.
It seems to me that some piece popped off and exposed this spring.
Has anyone else seen this problem? I have 45K miles, so I'm still covered, but if it's something I can just pop on; I'd rather fix it than drive all the way to Atlanta.
Rawhyde
Old Dec 26, 2006 | 06:19 PM
Rawhyde's Avatar
Rawhyde
I took the car down to Global Imports and they replaced the entire passenger side headlight! I did some research on Realoem.com, and the washers ARE a separate part, but they replaced the whole headlight anyway. They told me that they wanted to make sure that everything was as shipshape as possible since I was almost out of warranty.
No doubt about it....ALL 5's!
Rawhyde
OutMotoring
Mar 3, 2017 06:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
