Tire Pressure ??
Old Dec 17, 2006 | 07:25 AM
DOT191's Avatar
DOT191
Tire Pressure ??
Our MC has 15" Holies with 175/65R-15 Tires. The plate on door sill calls for 30PSI for a light load & 35PSI for full load. I have been running the tires at 35 PSI no matter what load is. Why? Because it Handles ,in my opinion , much better. Am i okay doing this or am i causing excessive Tire wear? Thanks. The car which was purchased new only has 19,100 original miles on it & still on the original tires.
2003 MC. PW/B, Premium PKG, DSC,CVT, Fog Lamps, After MKT Spoiler & after MKT Center & Door Armrests
Old Dec 17, 2006 | 07:52 AM
Crashton's Avatar
Crashton
I don't believe you are hurting a thing. That being said over inflated tires will wear the center of the tire out faster then the edges. It's a trade off, better handling for less tire life. What's more important to you? For me it would be handling.
Old Dec 17, 2006 | 08:10 AM
jimmy_racoon's Avatar
jimmy_racoon
Same Tires
DOT191, I have the same tire set-up on my 2005 Cooper.
Just turned 33,500 on the original tires before I got a new set.
Have run them entirely at 35 PSI and I rotated front to back to even wear.
Probably could have gotten many more miles but I just love the corners too much!
Motor on.
Old Dec 17, 2006 | 08:33 AM
DOT191's Avatar
DOT191
Thanks for the input. I agree that the Handling is what i want.So i will continue to run them at 35PSI. Forgot to mention i was able to purchase a set of 4 of these type Tires with 1,000 Miles on them dirt cheap awhile back so i have a Back up Set when i need to change the Tires,
Old Dec 17, 2006 | 09:40 AM
xtremepsionic's Avatar
xtremepsionic
I ran 41 front and 36 rear with the same tires on holies for about 16000 miles, there were still about 3/16th of an inch left when I swapped them out. Only about 0.5/16th of an inch more wear in the center of the tires, I liked the slightly stiffer sidewall for steering response.
Old Dec 17, 2006 | 01:09 PM
DOT191's Avatar
DOT191
Dot191
How Old do yo have to be to Join the " Old Farts Motoring Club"?? I believe
may Qualify for Membership,
Doug
Old Dec 17, 2006 | 04:00 PM
Crashton's Avatar
Crashton
Doug
Welcome to the club Doug. There are no dues or sign ups. Being an Old Fart is all that's required.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
