R50/53 CVT Operations Question
Old Dec 9, 2006 | 05:22 PM
PKAT's Avatar
PKAT
I need help in understand the modes on the CVT.
They are as follows: AUTO, SD, MANUAL
Auto: No questions
Manual: Switching from auto to manual, you go into SD then shift normally.
When you shift down and go in to low, 1st shows on the display. Yet when you shift for the first time to the manual mode, SD is what shows.
Is this just an indicator that you are now in the "manual" mode???? Or are there 3 modes instead of two?
The transmission works great in manual as there is no way that you can "lug" the transmiission. It will not let you change until you have enough speed or rpm to do so.
Thanks for help in solving this question.
Old Dec 9, 2006 | 05:53 PM
MotorMouth's Avatar
MotorMouth
There are 3 modes.
D = "drive"shifting about 2500 rpm under normal driving.
SD= "sports drive" shifts about 4000 rpm under "normal" driving - (SD is not used for "normal") it's good for going up steep hills.
1-6 = manual
If you push the pedal to the floor it'll go all the way to redline in any mode.
It won't go over 4000 rpm in "D" unless you press the pedal past the "click".
Old Dec 9, 2006 | 09:50 PM
Monk Edsel's Avatar
Monk Edsel
I don't use SD to go up hills, I use it when I want to accelerate more quickly than normal. If I floor the pedal (past the click) in D mode, is that the same as having the car in SD mode then?
Old Dec 10, 2006 | 01:07 PM
MotorMouth's Avatar
MotorMouth
Pushing past the click is not the same as SD mode. That takes you past 4000 rpm.
SD mode will just keep the ransmission from upshifting until you get to about 4k rpm vice the ~2500-2700 rpm normal shifting (with normal gas pedal pressure).
donniedarko
Oct 21, 2015 01:15 PM
KristaMcCoy
Sep 12, 2015 05:37 PM
StillK
R55 :: Clubman Talk (2008+)
Sep 10, 2015 12:17 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 4, 2015 09:23 AM
