R50/53 My Real World MPG
Old Dec 7, 2006 | 11:27 PM
Mini-Wingnut's Avatar
Mini-Wingnut
My Real World MPG
Here's my actual MPG from the first 2000 miles (MCS). The interesting thing is that the OBC rates me at 21.2 MPG. One would have to drive like "the little old lady from Pasadena" to get anywhere near what the window sticker states.
Old Dec 7, 2006 | 11:33 PM
Arthurbang's Avatar
Arthurbang
I have the regular Mini cooper, not an S, but I've had mine for almost 3 months (shortly after you, on September 18th, also from Long Beach Mini btw). And I have not had anything lower than 28 mpg. I took the car up to San Francisco this weekend and had two 31 and 32 mpg tanks for the trip up and back. I believe my OBC says somewhere between 28-30. My average mileage per tank is usually close to 375, even though the OBC usually tells me I can go about 425.
For what it's worth, I drive 5 days a week to work from Huntington Beach to Anaheim, and then my girlfriend lives in Long Beach and head there several days a week. Just out of curiosity, how many miles have you racked up so far?
Old Dec 7, 2006 | 11:50 PM
Motor On's Avatar
Motor On
It's a baby engine you've got to wait a while, stock I averaged 24 highway with some city, ALTA CAI less humidity even highway city mix I know get 28-30, 33 highway when around 70 (decrease over that speed) and I can pull in 35-36 if I'm under 60 and no traffic to deal with (rural non highway) I don't have an OBC so I use a similar method to your chart. BUt after a year I'm at 45.8k so everything runs a little more cohesive.
Old Dec 8, 2006 | 12:10 AM
Arthurbang's Avatar
Arthurbang
I now see that you're at around 2000 miles. Amazingly, in less than 3 months, I already have around 5500 miles on the car.
Old Dec 8, 2006 | 12:17 AM
abuzavi's Avatar
abuzavi
With a stock 06 S and 700 miles, I'm averaging 22+ MPG.
Of course, I live in Germany, love the autobahns, and drive it like it's stolen. Still, 22 is acceptable for the conditions!
Old Dec 8, 2006 | 12:28 AM
Motor On's Avatar
Motor On
Thats a lot better than I'd get in your situation. I have proved the driving like I stole it (time on a road course) to mean 15mpg of course you're still in the break-in and shouldn't be much past 4500 RPM yet, 5l-6.5k is a golden good time, and worth the wait
Old Dec 8, 2006 | 12:37 AM
R56MCS's Avatar
R56MCS
My 07 MCS is now down to 34 mpg, but most of its 200 mile shave been in urban conditions so I'm not suprised.
I run mine on 97 octane though, may be this has something to do with it. Standard fuel is 95 RON in the UK, premium is 97/98, as far as I know we can't even buy 91 here. Assuming that 91 costs less you may find that compared with more expensive fuel you are getting further per buck.
Old Dec 8, 2006 | 10:06 AM
thomasdmini's Avatar
thomasdmini
I've been quite surprised at the drastic effect even "a bit" of urban driving does to the average on a tank. About 4 miles of my 18 mile commute is "traffic/ traffic light" type driving. It can very quickly take me from a 28/29 mpg to a 21/22 mpg. The traffic-y stuff is all accelerate, stop, sit driving.
Reports on Mixed-use "fun but not psycho" MPG averages for the MCS seem to cluster around 24mpg. Haven't heard too many convincing reports outside of that average.
Old Dec 8, 2006 | 10:17 AM
jibeho's Avatar
jibeho
I get 27-30 MPG even on tanks that I track with. I have notice a slight bump now that I don't run the A/C as much.
Old Dec 8, 2006 | 10:25 AM
H.A.W.G.'s Avatar
H.A.W.G.
I havent done the math, but I get a little more than 400 miles to the tank
Old Dec 8, 2006 | 11:29 AM
MaxN's Avatar
MaxN
Reverse Gear
There is a difference between the US and Europe octance systems used.
In Europe you use the RON value, in the USA it is (RON+MON)/2
from wikipedia....
Research Octane Number (RON) is determined by running the fuel through a specific test engine with a variable compression ratio under controlled conditions
Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance.
Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-95 (regular) in Europe.
Effectively running on 97/98 in Europe is the same as running it on 91 (maybe 93) in the USA.
valcom111t's Avatar
valcom111t
According to the computer, I'm getting 27.6 with my MCS with 1600 miles. Judging from the way I drive, you all must be totally nuts!
Old Dec 8, 2006 | 11:40 AM
MaxN's Avatar
MaxN
Reverse Gear
Over the last (ahem) 37K miles, my MCS has averaged 24.5mpg according to the OBC. The speedo is a little out compared to the GPS, it is 3-4% over.
Calculating from the fuel stubs and GPS distance travelled on a few long trips I put the error at less that 1/2 mpg. On my mix of road-trips, commutes, track days and california traffic I think that 24-25mpg is acceptable.
The absolute best I have seen is 31mpg, the worst is single-figures at Laguna Seca where I was consuming ~30% of a gallon of gas every lap........
Old Dec 8, 2006 | 11:44 AM
jst4fun's Avatar
jst4fun
Coordinator :: Alabama Motoring Society
Wow, I have an 05 now fully DINANed but even before any MODs I never got worse than 26 even in everyday city traffic. Musta been that Alabama clean air...
Old Dec 8, 2006 | 11:45 AM
rrudorf's Avatar
rrudorf
I am relatively easy on the gas and get a combined 25.2mpg always.
RR (05 MCS)
Old Dec 8, 2006 | 12:05 PM
scooterboy's Avatar
scooterboy
I can get the advertised 37 mpg in my MC if I limit myself to 65mph on the highway. Since I never do that, I end up with 33-34 mpg instead. I always get at least 450 miles out of a tankful.
Old Dec 8, 2006 | 12:06 PM
2bkalm's Avatar
2bkalm
actual miles
yes: I got my MCSca on Nov 8th '06 and I'm get really bad milage too. It's starting to worry me a bit because when I bought it I read stuff about how good MPG they get...I have a bit over 2000 on at I'm averaging about 18 mpg with mostly local driving and I have to fill up at around 240 miles on speedo. So the real question is how long is the break in period until I will see an increase of MPG ?? km
Old Dec 8, 2006 | 12:07 PM
fj0's Avatar
fj0
I average 18-19mpg.
Old Dec 8, 2006 | 12:13 PM
callen's Avatar
callen
My
2006 MC gets 30 mpg...no matter where I drive it....city or hwy. Course on hwy its 70 plus mph. I've got about 12K miles on him now. Thought it would go up after broken in..but not yet. I don't use OBC...use Odom and gallons.
Old Dec 8, 2006 | 12:17 PM
redhotchilis's Avatar
redhotchilis
I've got 4,800 miles on my MCSa and I've averaged around 24mpg. Best was 26, worst was 22. The tank I'm working on now is definitely on track to set a new low - I've been using the manual mode hard in the last few days.
Old Dec 8, 2006 | 12:20 PM
jymontoya's Avatar
jymontoya
WHO CARES! it's fast!
Old Dec 8, 2006 | 12:28 PM
fj0's Avatar
fj0
Old Dec 8, 2006 | 12:32 PM
mbcoops's Avatar
mbcoops
I don't drive like the little old lady from pasadena, and my 05 MCS gets right around 30mpg. I do a lot of highway driving. Two tanks ago I got horrible mileage, somewhere south of 25 mpg, so I put in a bottle of Redline SI-1 and now all is back to normal.
mb
Old Dec 8, 2006 | 12:35 PM
MiniBetterThanBeer's Avatar
MiniBetterThanBeer
Hey Mini-Wingnut!
I did my own mpg calculations too and here's what I got for the first year of ownership:
24.723 mpg from mixed driving at a cost of $0.111/mile (last year's prices ranged from $2.099 to $3.739/gallon -- remember that crap in September?!).
Before the MINI arrived, I committed to always filling-up (to know how much of the previous tank is consumed), saving the receipts, and then plotting everything on a spreadsheet. I knew there'd be many uncontrolled variables (such as seasonal temps, times of day, lead-footing, etc.) but I just wanted to find out if different gas chains could have better gas, if my driving style could shame the EPA estimates, and whether my gas expenditures could feed all the children on that commercial...
Yes, everyone, I had a lot of free time; for every fill-up I lost a whopping 15 seconds of my life that I never got back! I don't think all those people who also lost 15 seconds waiting for me to pull away ever got their time back either... but the information gleaned from my pseudo-scientific study was worth the trouble. Especially knowing that I could fatten all of those children...
Old Dec 8, 2006 | 02:24 PM
BECOKA's Avatar
BECOKA
How did you get an 07' so quickly?
