Interior/Exterior which antenna......?
Old Dec 4, 2006 | 01:28 PM
vestanpance's Avatar
vestanpance
Which short and stubby antenna do you guys recommend that still keeps the best signal? And how much signal do you lose when switching from the stock antenna?
Old Dec 4, 2006 | 01:48 PM
uscfan's Avatar
uscfan
I use an S2000 antenna and don't lose any reception as far as I can tell from stock.
Old Dec 4, 2006 | 01:51 PM
ChrisW's Avatar
ChrisW
I have the alta and it works as good if not better than the stock one.
Old Dec 4, 2006 | 01:53 PM
Methman's Avatar
Methman
Alta.
Old Dec 4, 2006 | 04:22 PM
///ACS330Ci's Avatar
///ACS330Ci
S2000 ... a lot cheaper than Alta's
Old Dec 4, 2006 | 04:23 PM
Motor On's Avatar
Motor On
+1
Old Dec 4, 2006 | 05:20 PM
IrishCooper's Avatar
IrishCooper
Its also alot taller than the Alta.
I have the Alta and i didnt notice a difference in reception works great and fits the car better than the S2000 cause its just the right size, not too big and not too small.
Old Dec 4, 2006 | 05:31 PM
GoodFinder's Avatar
GoodFinder
I have two of the shorter antennas, one is the S2000 and the other is from Craven Speed. I like the looks of the Craven Speed better, but the S2000 gives better performance (similar to stock). Based on the above comments, sound like I need to try the Alta, too (since I'm running with Craven Speed normally because I like the shorter length).
Old Dec 4, 2006 | 05:53 PM
cartar452's Avatar
cartar452
i use an Alta and the reception seems the same... i believe they actually have a newer one out now that is a little shorter than the one i have
Old Dec 4, 2006 | 05:58 PM
Red Scooter's Avatar
Red Scooter
Just ordered this one. Not too worried about reception but I'll let ya know.
Old Dec 4, 2006 | 06:31 PM
Larry Clemens's Avatar
Larry Clemens
Love my Alta
Old Dec 4, 2006 | 06:37 PM
gokartride's Avatar
gokartride
I have an S2000, but if I were to do it all over today, I'd probably go with Alta. Not a big deal for me though, so I'll keep what I've got. However...there's always the next MINI!!!
Old Dec 4, 2006 | 07:07 PM
Motor On's Avatar
Motor On
You have a mod!!!!!!
Old Dec 4, 2006 | 07:09 PM
gokartride's Avatar
gokartride
Shhhhhhh!!! I simply replace the antenna with what should have been there to start with.
Old Dec 4, 2006 | 07:20 PM
Motor On's Avatar
Motor On
Well I'll still let you say your car is all OEM, its just not as pure as I had once thought
Old Dec 4, 2006 | 07:24 PM
vestanpance
where do you buy a Alta? can I get a link?
Old Dec 4, 2006 | 07:26 PM
gokartride's Avatar
gokartride
Then I probably shouldn't mention the brake-light mod either. Hey, the bulbs were there, I just make practical use of them!!
Old Dec 4, 2006 | 07:29 PM
Motor On's Avatar
Motor On
(But still technically OEM)
Old Dec 4, 2006 | 07:36 PM
Fatherdeth's Avatar
Fatherdeth
S2000 for me. I like the idea of walking into a local dealership and buying an antenna instead of waiting for it in the mail. Plus, I think the Altas are too short.
Old Dec 4, 2006 | 08:11 PM
cartar452's Avatar
cartar452
http://www.altaminiperformance.com/p...horty-Antennas
Old Dec 4, 2006 | 08:25 PM
ChrisW's Avatar
ChrisW
You can find the Alta on Ebay for about $7 like i did.
Old Dec 4, 2006 | 08:26 PM
slvrmni03's Avatar
slvrmni03
No Antenna! Who needs AM radio anyway?
Old Dec 4, 2006 | 08:35 PM
kapps's Avatar
kapps
I heard somewhere a while back that the MINI uses the wiring for the rear window defogger along with the actual antenna to pick up radio. It supposedly uses the difference between the two to pick the better signal. Because of this, there is little quality lost when switching to a small antenna. I'm not sure if this info is true or not, though.
Old Dec 4, 2006 | 08:39 PM
ChrisW's Avatar
ChrisW
I didn't really care if i lost alittle bit i listen to Sirius about 98% of the time. I just hate the way the OEM one looks. But when i do listen to the Norm radio i havn't notice a difference.
Old Dec 4, 2006 | 09:37 PM
Jahmills's Avatar
Jahmills
Somebody just stole my regular antenna recently, I just put a little rubber plug in the hole to keep debris out of it until I replaced it. It occured to me that I never listen to the radio anyway since I got Sirius and my ipod. I think I'm just going to leave it that way. That punk who stole it may of actually done me a favor.
