R50/53 If you have LSD......
Old Nov 23, 2006 | 10:40 AM
Herby74's Avatar
Herby74
.......do you hear a slight, high-pitched groan starting out in first gear like I do? I'm told this is common in cars with LSD. It's slightly annoying. Can anything be done about it?
Old Nov 23, 2006 | 10:42 AM
Motor On's Avatar
Motor On
THere is a TSB on the subject, if you complain to the dealer they can change the fluid to one that is more silent, however I thought it applied to cars before yours, now I need to check....
Old Nov 23, 2006 | 11:37 AM
Johnna's Avatar
Johnna
LSD Groan threads
Herby,
There are a couple of threads discussing LSD groan. Usually an '05 issue for tight turns at low speed. Yours happens when starting out in first.
My '02 MC had a singing clutch sometimes when starting out. Fixed with clutch replacement at 30K.
The middle thread is a little different and refers to grinding noises.
Happy reading ......
https://www.northamericanmotoring.co...ight=LSD+groan
I hope that helps you out.
John
Old Nov 23, 2006 | 11:42 AM
Motor On's Avatar
Motor On
http://www.alldata.com/tsb/BMW/11387...06/230106.html
Old Nov 27, 2006 | 05:29 PM
Herby74's Avatar
Herby74
The info is much appreciated, especially since the dealer didn't mention it. The groan seems to be affected more by colder temperatures, so I'll wait to see what happens....won't be long. It's nice knowing that a potential fix is out there.
Old Nov 27, 2006 | 05:55 PM
ma78's Avatar
ma78
Coordinator :: Super Secret Orange County MINI Cooper Club
Remember, the power steering motor makes a similar sound. Some people have confused them.
