Interior/Exterior M7 Splitter Durability/Impressions
Old Nov 21, 2006 | 03:28 PM
uscfan's Avatar
uscfan
I am thinking about picking up an M7 splitter this x-mas as a present for my MCS. My only concern is that I eventually want to lower my car, and there are also a lot of speed bumps where I live. So, for those of you that have a splitter, is you car lowered? How long have you had the splitter on? Have you had any problems in terms of scraping or scratching during speed bumps or inclines? And how has it held up since you've put it on?
Old Nov 21, 2006 | 03:44 PM
vm's Avatar
vm
I don't have a splitter, but if you want to low 1"+ the MINI will be useless with bumps and ramps.
Old Nov 21, 2006 | 03:51 PM
jimz68's Avatar
jimz68
I've had an m7 Splitter for quite a while. The car is lowered with H-Sport Springs and I scrape the factory air lip that hangs down behind the splitter. I have only had the splitter scrape a couple of times, and then it was very minor. The hardware for the braces hit before the actual splitter does.
Ask Randy from m7 how well his has stood up.
Hope this helps,
Jim
Old Nov 21, 2006 | 03:53 PM
MSFITOY's Avatar
MSFITOY
55,000 miles, 130+ and still holding... Even flew over a few roadkills at night that made some nasty racket under the Mini but never damaged the splitter...
If you don't watch your speed over speed bumps and clearance towards parking curbs...you will break not only the splitter but your bumper with it...with or without the splitter...
Yes mine is very lowered...
Old Nov 21, 2006 | 03:57 PM
OctaneGuy's Avatar
OctaneGuy
I've got the Strassentech front lip with HSports, and when I run with 15" wheels (205/50) (Flik Fuels), I scrape on speed bumps, and everywhere I go. It's really not a practical daily driver combo.
With 17" wheels (205/45) Flik Bullets, I only scrape on speed bumps if I take it too fast--but if slow down, like how speed bumps are supposed to make you do--I no longer scrape.
I've scraped my lip only on steep driveways, otherwise it's always the lower portion of the factory lip.
So I think it depends a lot on wheel size and how you drive.
Richard
Old Nov 21, 2006 | 04:02 PM
vm's Avatar
vm
What your saying is that my speed bumps are really walls? I have some problems with some of them. If it's liveable, I'll like it on my next MINI.
Old Nov 21, 2006 | 04:03 PM
MSFITOY's Avatar
MSFITOY
Beware of add ons like Hammon splitters...they are nearly an inch or more below the bottom of the bumper...
M7 splitter is a thin CF plate that does not create additional clearance problems that you may already have from lowering your Mini...maybe add another 1/4"
Old Nov 21, 2006 | 04:07 PM
uscfan's Avatar
uscfan
I run 215/45/17 and don't go over speed bumps too fast, so I guess I should be fine. I just worry that lowering the Mini and adding a splitter won't leave very much ground clearance for debris I might run into on the road. But from what Msfittoy says, I guess I shouldn't be too worried. I thought I remembered reading a while ago about someone who had an M7 splitter that hit some debris on the highway and tore off part of their front bumper. But maybe that was on M/U.
Old Nov 21, 2006 | 04:10 PM
uscfan's Avatar
uscfan
Hmm...1/4" more doesn't sound too bad. If I lower the car it will probably only be about 1" with H-sports, so with that combo I should be fine.
Old Nov 21, 2006 | 04:17 PM
Scooby03's Avatar
Scooby03
That might of been me. I jumped a culvert and broke part of it. Did more damage to the bumper and side molding than the splitter. My MINI is lowered and running 40's. I will be putting a new splitter (M7) on my Aero kit.
Old Nov 21, 2006 | 07:41 PM
MINI Monkey's Avatar
MINI Monkey
I just installed mine last night. I still have a few things to button up before I take it out on it's first trip. It looks great! Randy and Peter have top notch service too. I'm not too worried about it scraping. Randy has used his longer than anyone and it's seen a couple of off track excursions, still looks perfect. I'd say it's pretty sturdy.
Old Nov 22, 2006 | 08:17 AM
mbcoops's Avatar
mbcoops
Is the splitter functional at all? Does it help aerodynamics at certain speeds, or is this a style mod?
Thanks!
mb
Old Nov 22, 2006 | 09:34 AM
ImagoX's Avatar
ImagoX
Does anyone have a photo of the ENTIRE splitter from different angles? All I can find on Detriot Tuned's site is a partial shot of the splitter and one turnbuckle. I want to see what the ends of the splitter look like please.
Thanks!
Old Nov 22, 2006 | 02:28 PM
MSFITOY's Avatar
MSFITOY
Thanks!
Old Nov 22, 2006 | 02:34 PM
cycleguru's Avatar
cycleguru
I've had my front splitter on for about 1,000 miles and i live in a community that has a ton of speed bumps. As long as i go over them slow i'm fine. I also have H-sport springs. The only thing that i scrape sometimes when i hit a "whoop dee do" in the road is the very bottom lip of my OEM aero front end. Which is located at least 12" farther back from the front of the splitter. But my M7 aero front splitter has cleared so far. I love the look. Its all about the functional "BLING" Don't you know
You can see some pics at my Gallery or the latest issue of MC2.
Old Nov 22, 2006 | 02:54 PM
ImagoX's Avatar
ImagoX
Thenks MSFITOY!
Does anyone know if the turnbuckes can be had as a seperate componant from anyplace? I'm honestly torn between this unit and the one that StoopidGirl's selling over in the Marketplace forum - problem is I like her unit's looks better but it doesn't have the cool support peices.
Old Nov 22, 2006 | 03:33 PM
MSFITOY's Avatar
MSFITOY
Thenks MSFITOY!
As long as it's approximately 6" end to end (with some adjustments), you'll be ok to use any brand of standoffs
Just remember...the other design is cool looking but extends down another 1" plus so you'll need to be extra careful...
From the performance view, a flat/horizontal splitter like the M7 is more functional...and more forgiving...
Old Nov 23, 2006 | 08:39 AM
ImagoX's Avatar
ImagoX
I'm hoping someone will post a picture of the underside of that splitter - I've heard it sticks down as little as 1/4" some places and up to an inch other places.
I'll try searching for "standoff" - looking up "turnbuckle" got me lots of hardware for guy-wire applications.
Thanks!
Old Nov 23, 2006 | 08:47 AM
MSFITOY's Avatar
MSFITOY
Thanks!
Sorry I can't get my camera that low but I'll see if a friendly snail can take a pic
The bolts may stick down a little farther if you don't trim them but an inch? No Way...
You can find these types of standoff at your friendly sailboat shop...
Old Nov 24, 2006 | 11:13 AM
Jonwalks's Avatar
Jonwalks
I have an M7 Splitter
the M7 splitter not only looks great but it has not bottomed out yet and i have alot of speed bumps in my area too. is very sturdy and the silver hanger connections look great. the only warning is if you are pullin into a space with a parking stopper you have to be very carful b/c if you hit it that splitter is gone
Old Nov 24, 2006 | 11:31 AM
CooperSS's Avatar
CooperSS
Here is a closer look at the splitter.
My car is pretty low and the splitter has survived many a mile.
You can see the splitter does not lower the front end very much at all.
Bill
Old Nov 24, 2006 | 11:41 AM
Longboard Mini's Avatar
Longboard Mini
I have had mine for about a year. I really like the way it looks. It is small and clean looking. The others are big and just don't look right to me.
Like said before, you just need to be careful around parking blocks and curbs.
Longboard
Old Nov 26, 2006 | 10:26 PM
COR BLMY's Avatar
COR BLMY
Can anyone give me help finding hardware ???
A link, company etc ?
Old Nov 26, 2006 | 10:31 PM
COR BLMY's Avatar
COR BLMY
Found this if it helps anyone
http://www.bosunsupplies.com/Deck_Stanchion.cfm
Old Nov 26, 2006 | 11:09 PM
MINI Monkey
Nice photos! I need to take my MINI someplace nice and get a few pictures worth sharing. The Aero Splitter looks great--CooperSS.
