R50/53 Sunroof - manual retraction
Old Nov 20, 2006 | 05:05 PM
CTDAVID's Avatar
CTDAVID
Okay- I got blasted here for asking how to set the clock, even though I cannot find those instructions in the manual. This time I have the instructions, but they don't seem to reflect the reality of the car. I know there is an allen wrench in the secondary toolkit for cranking the sunroof shut, but on my 2006 MINI S, there is no place to use it. I looked. All I have is what had been referred to here as the "sad clown face" No little hatch to slide back or hinge down. Now so far this hasn't been an issue, but since I do use the roof a lot, I would like to be able to retract it if I do have a power problem. Anyone?
Old Nov 20, 2006 | 05:07 PM
RA080624's Avatar
RA080624
i think you have to take the clock assembly off and i believe its under there
Old Nov 20, 2006 | 05:29 PM
billie_morini's Avatar
billie_morini
In the event of an electrical malfunction
you can open and close the glass sunroof
manually
1. Slide the cover panel towards the interior
remove it
2. Use an Allen key to turn the glass sunroof
the direction required.
Old Nov 20, 2006 | 07:16 PM
CTDAVID's Avatar
CTDAVID
You missed my point
Billie- I found that same diagram in the manual. However there is no corresponding hatch in the car itself, as far as I can tell.
Old Nov 20, 2006 | 07:25 PM
JustJAY's Avatar
JustJAY
There is no clock there in an '06
Old Nov 20, 2006 | 10:24 PM
billie_morini
CTDAVID,
It is not simply a little door or hatch. You have to remove an entire little console that has switches in it. Because of this, it isn't something you'll do often. The console is located between the mirror stalk and the (larger)console that houses switches for the sun roof.
Billie
PS: I was able to set my clock tonight thanks to your other thread about "how to." Thanks.
Old Nov 20, 2006 | 10:31 PM
valcom111t's Avatar
valcom111t
You pull out the piece that has the airbag light on it. I think the reading lamps are on it too. You'll feel like you're hurting your car when it pulls out.
Old Nov 20, 2006 | 11:38 PM
Jtrem's Avatar
Jtrem
ive had to close my sunroof manuelly. No fun at all.
Old Nov 21, 2006 | 03:53 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Yeah there is. It's in the speedo. You alternate between the trip odo and the clock using the little push button thingy.
Old Nov 21, 2006 | 05:26 AM
Rawhyde's Avatar
Rawhyde
You have to remove the front reading lamp assembly before you can use the tool to manually close the roof.
Sorry about the treatment you got in the earlier thread. Some people get a big jolly from slamming on a newbie.
Rawhyde
PS I wouldn't make a habit of working the roof manually. That panel with the reading lights isn't designed to be removed and replaced on a regular basis. It'll break sooner rather than later.
Old Nov 21, 2006 | 06:50 AM
Louispup's Avatar
Louispup
I love the sunroof, use it most every day. I'm also spritely driving through my warrantee, just wondering how many people have had problems with the sunroof- and what it costs to have repaired. Guess I could run a search, thought I'd just raise my hand.
Old Nov 21, 2006 | 08:36 AM
jonnieoh's Avatar
jonnieoh
If any parts break due to you having to shut the sunroof manually, I would imagine your warranty would cover that, (if the service advisors at your dealership aren't jerks).
Old Nov 21, 2006 | 08:52 AM
ImagoX's Avatar
ImagoX
Agree - just tell them that it was looking like it would rain and you were trying to avoid soaking he interior (which would be a MUCH MORE EXPENSIVE warranty claim).
Lex2008
How to
47
Jun 15, 2022 06:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
