Interior/Exterior Easy way to remove Driving lights?
Old Nov 19, 2006 | 06:46 PM
scatpack's Avatar
scatpack
Is there any easy way to remove the driving lights??
The reason is: Im replacing my front grille and of course, I already have the driving lights installed. I dont want to cut the wires and have to reinstall them again thru the lights. Is there an easier way to remove them?:impatient
Old Nov 19, 2006 | 07:00 PM
kenchan's Avatar
kenchan
i thought those separated by a plug/harness. i could be wrong. been
a while since i did the install...
Old Nov 20, 2006 | 09:06 AM
Pir8 97's Avatar
Pir8 97
No easy way. I took the lights apart and removed the wires from the inside, but I did have to cut a wire since the end wouldn't fit through the hole. You'll also have to drill out the rivits on the brackets or mutilate the old grille to get it off.
Old Nov 20, 2006 | 12:13 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Pir is 100% correct. That's exacly what I had to do too. Had to buy a rivet gun and some wire end connectors too.
Old Nov 20, 2006 | 01:07 PM
scatpack's Avatar
scatpack
What is riveted? My light 'hangers/brackets' are screwed in with 3 screws.
Old Nov 20, 2006 | 04:43 PM
Agro's Avatar
Agro
The dealership install has the black brackets riveted to the underside of the bonnet. If you have screws, you either had a "non-standard" installation or they weren't installed by a dealership.
Old Nov 20, 2006 | 06:15 PM
scatpack's Avatar
scatpack
Mine came with the lights from the factory actually with screws.
Old Nov 21, 2006 | 02:22 PM
Agro's Avatar
Agro
Wish mine had screws. I had to buy a rivet gun and learn to use it.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
Zettinger
Aug 25, 2015 04:04 PM
