aftermarket wheel center bore
Old Nov 15, 2006 | 08:37 PM
ltg123's Avatar
ltg123
i was just wondering what are the most common centerbores of wheels that require hubcentric rings for the mini coopers. i know 73mm is one. are there any others? any info would be great.
Old Nov 16, 2006 | 09:00 PM
ltg123's Avatar
ltg123
anyone?
Old Nov 16, 2006 | 09:21 PM
W3IWI
The hub has a diameter of 56.1 mm. Wheels with any larger size need hubcentric rings.
I have 16" Rota Slipstreams with 67 mm holes. Most dealers have molded (i.e. plastic) rings. A friend found me metal ones at a local Discount Tire store.
Old Nov 17, 2006 | 05:49 AM
ltg123's Avatar
ltg123
thanks, i know the hub size of the mini, what i want to know is the most common centerbore sizes of aftermarket wheel for the mini. so i assume 67mm is one.
does anyone else have any input?
Old Nov 17, 2006 | 08:58 AM
949Racing's Avatar
949Racing
57.1, same as the 4x100 BMW
Old Nov 17, 2006 | 02:38 PM
ltg123's Avatar
ltg123
are you saying the stock mini hub is 57.1 mm and not 56.1?
Old Nov 17, 2006 | 05:07 PM
949Racing's Avatar
949Racing
My bad, 56.1 is correct.
Old Nov 17, 2006 | 08:10 PM
Passat774's Avatar
Passat774
He asked what are common hub bore's.. 72.62, 73.00 & 74.00 mm are all common hubs. 73.00 is the most common..
Old Nov 18, 2006 | 07:32 AM
ltg123's Avatar
ltg123
wow, thank you. that was the info i was after!
Old Nov 18, 2006 | 10:49 AM
cristo's Avatar
cristo
Alliance Member
My SSR's are 72.2 mm, and my wife's ASA's are 73 mm.
Old Nov 18, 2006 | 12:15 PM
Passat774's Avatar
Passat774
Welcome
Old Nov 18, 2006 | 07:56 PM
ltg123's Avatar
ltg123
wheel spacer/hub adaptor
the reason why i asked this question is i am thinking of producing a wheel spacer that will also be an adapter to the larger hub of the aftermarket wheel being used thus doing away with the need for hubcentering rings. the design will also allow me to make a 5mm spacer with an extended hub on it, where as most spacers under 10mm do not have the hub extension built in. anyone that is interested should let me know. i have the design already, i am going to do a prototype and then hopefully a production run. i think i am going to start with a 5mm thick- 56.1mm to 73mm spacer/hub adaptor. if something like this already exists i haven't seen it, please tell me if you have and where it is located.
thanks,
lorenzo
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
