R50/53 Window squeek help needed!!
Old Nov 10, 2006 | 07:48 PM
solberg's Avatar
solberg
Does anyone else have an annoying squeek when the windows are all the way up? It appears to be coming from where the glass meets the rubber weatherstripping at the top and is present on anything other than perfectly smooth roads. Any suggestions for a fix would be greatly appreciated. Thanks
Old Nov 10, 2006 | 09:32 PM
BradB's Avatar
BradB
I wiped down my seals with powder and that did the trick. This is a factory fix trick used by Porsche and BMW.
Old Nov 10, 2006 | 09:34 PM
mini b's Avatar
mini b
Mine did the same thing. Turned out to be the window regulator. Dealer fixed under warranty.
Oops, just noticed you're talking about when the window is up...sorry. Mine squeeked as I was rolling it down.
Old Nov 10, 2006 | 10:09 PM
Eric_Rowland's Avatar
Eric_Rowland
Mine didn't use to do that. Then I went in for some warranty work and they 'fixed the problem'.
Now they do.:impatient
I was going to try silicone lube. Brad, what powder did you use?
Old Nov 11, 2006 | 02:16 AM
solberg's Avatar
solberg
I have actually tried some talcum powder and it did seem to help some extent. Maybe I'll try that again and use more of it. Is there a certain type of powder that works best Brad?
Old Nov 11, 2006 | 09:40 AM
Kellzir's Avatar
Kellzir
Would it be safe to use if the front windows are tinted?
Old Nov 11, 2006 | 09:46 AM
daemon2's Avatar
daemon2
Mini recommends talcum powder or silicone lubricant. No oil based lube should be used.
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
